FERCSA HACKING firmware.
I have a 70MHz DSOX1102G I bought in 2018. I was interested in increasing the bandwidth to 100MHz, but I found the KS upgrade a bit expensive. Searching in this forum, I found the FERCSA HACKING firmware. At first I was a bit afraid that something went wrong, but I decided to install the FERCSA HACKING firmware on my DSOX.
The installation was done successfully, it took 3 minutes and in the end even the soft reset worked perfectly. Now I am very happy because I got a bandwidth of 200MHz and the time base now reaches 2nS (before the minium was 5nS) WOW
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
-I've attached some photos comparing the before and after and the installation process.
-I measured a signal from a 125MHz TCXO oscillator (before and after photo).
-I measured the SPI protocol of an Arduino (pictured below).
FERCSA, thank you for sharing this brilliant work and continue the development!
Good luck to everyone.
