Author Topic: EEVblog #978 - Keysight 1000X Hacking  (Read 494570 times)
Online TheSteve
  • Living the Dream
Re: EEVblog #978 - Keysight 1000X Hacking
« Reply #550 on: December 27, 2018, 04:34:21 am »
You will always get more noise with increased bandwidth.
VE7FM
The following users thanked this post: TK
Offline hv222
« Reply #551 on: December 27, 2018, 10:33:47 pm »
Schematic of function generator and group of components located between analog front-end and function generator. This group probably handle the signal offset and part of user calibration. Some power supply components like ferrite beads and decoupling capacitors can be missing in power supply lines. I will appreciate I someone can measure capacitors and inductors values in function generator. Is amplitude of generated signal constant while changing frequency? I add generator function to my scope, but signal shape is not satisfied :(
U31 and U33 are SN74HCT04PW
U46 and U47 are TL274
« Last Edit: December 27, 2018, 10:38:37 pm by hv222 »
Offline hv222
« Reply #552 on: December 27, 2018, 10:49:52 pm »
Schematic of connectors between two boards and LCD FFC connector. Pin numbers are not equal to pin numbers provided by connector manufacturer. Geometrical location on schematic is matching with connectors location on analog board. Connectors are FCI / Amphenol Bergstak series. 40pin, 2 rows, 0.8mm pitch. 61082-04xxxxxx.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #553 on: December 30, 2018, 12:29:07 pm »
On the new 4-channel DSOX1204G ( FW 2.00) , they seem to have added a "Host ID", in the form DSOX1204G,CNnnnnnnnn,xxxxxxxxxxxxxxxx where n is the serial no. and x are alphanumerics.
There is an option to save this to a USB stick - help on this says it is used for redeeming licenses.
Day Job: Mostly LEDs
« Reply #554 on: December 30, 2018, 04:11:34 pm »
The new DSOX1204G runs Linux, so back to square one...
Offline hv222
« Reply #555 on: December 30, 2018, 05:17:30 pm »
@mikeselectricstuff
Could you add more photos of 4ch version also with key board?
I try to share full schematic of 2ch version. It will be good point to compare both scopes.
« Reply #556 on: December 30, 2018, 05:21:30 pm »
@mikeselectricstuff
Not much time at the moment - let me know if there's anything specific
Offline hv222
« Reply #557 on: January 02, 2019, 12:44:26 pm »
It looks like 4ch scope have bigger NAND memory - 2Gb instead of 1Gb in 2ch scope. All Micron memories was replaced by Winbond. SDRAM memories remains same size.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #558 on: January 06, 2019, 02:59:10 pm »
If the new models going to use Linux and have soft power switch, it is possible to reduce the booting time.
I uploaded the video which it is used on the product. Chatting about the suspend to memory is mentioned in the later in the video.
« Reply #559 on: January 06, 2019, 03:58:47 pm »
The new 1204 has a real power switch
Offline bitseeker
« Reply #560 on: January 07, 2019, 03:15:31 am »
Hopefully, that's a sign that Keysight equipment designs will be more conscious of vampire power consumption.
Offline TK
« Reply #561 on: January 07, 2019, 11:13:27 am »
Agilent/Keysight scopes always had hard (real) power switches
« Reply #562 on: January 07, 2019, 11:17:38 am »
Nope.
Offline LapTop006
« Reply #563 on: January 07, 2019, 01:12:10 pm »
Not really, if the system is done well the boot time into application should be sub 5 seconds, getting the analog side ready for use likely takes almost as long, and would be needed on a return from suspend anyway.
Offline TK
« Reply #564 on: January 07, 2019, 01:42:38 pm »
Nope.
Sorry, I based my conclusion on the 1000X series and the 54622D (and other vintage HP / Agilent instruments)
Offline vladsol
« Reply #565 on: January 21, 2019, 11:44:49 am »
So... Have tried someone to patching files in, re-packing and flashing the nk.bin? :)
after all,  we all are interested in unlocking the licensed features :)
« Last Edit: January 21, 2019, 11:48:19 am by vladsol »
Offline IanMacdonald
    • IWR Consultancy
« Reply #566 on: January 22, 2019, 07:21:03 am »
6.5W may not sound much but over a year it adds up to about £8 at UK power rates, so over the life of the item it might add a significant part of its purchase cost.
Offline vladsol
« Reply #567 on: January 23, 2019, 07:37:48 pm »
I've found (maybe, this is not a news?:) ) that signature check is done in Agilent.Cdf.Api.Licensing.dl )
I patched this file to skip checking the signature in the license file. Now i need to try to replace this file in nk.bin, and install with the fw update.
Offline Bud
« Reply #568 on: January 23, 2019, 07:58:35 pm »
Let us know then if that worked...
Offline FERCSA
  • Country: hu
    • www.fercsa.com
« Reply #569 on: January 23, 2019, 11:39:24 pm »
@vladsol It's already done. Only one page back.. and you should find a modified ksx file which activates all the official and unofficial options, later one can't be activated with any license. Also if Keysight really switch over to linux on the 1xx2 series too, it's just not worth the time and effort to dig deeper into the current firmware.
@TK Did you have time to replace your LP filter?
@Mike Any news about a firmware update for the 4ch version?
Don't ask. I'm the same guy who gave you ultra fast internet in the '00s..
#FERCSA
Offline TK
« Reply #570 on: January 23, 2019, 11:51:36 pm »
Not yet.  I have the parts in the arrow shopping cart and waiting to order some additional components
Offline vladsol
« Reply #571 on: January 24, 2019, 03:57:12 am »
@FERCSA, I apologize, have not seen before. This is great news :) Thank you!
Installed on DSOX1102G
Serial decoding is working. The power analyzer, unfortunately, does not work.
« Last Edit: January 24, 2019, 08:37:28 am by vladsol »
Offline Bud
« Reply #572 on: February 06, 2019, 06:42:40 am »
Keysight EDUX and DSOX are on sale at Element 14. The EDUX is $503 Canuck coins , equivalent of only $383 Yankee bucks. Coupled with the hack in this thread - insane value. Got one, shipping was $20 CAD.
Offline TK
« Reply #573 on: February 06, 2019, 11:55:22 am »
There is a Keysight promotion: 15% for scopes <= 200MHz, 25% for >=350MHz
https://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=3015601&nid=-32110.1203277.00&id=3015601
It does not include the new 4-channel 1000X series
The following users thanked this post: Bud
Offline Bud
« Reply #574 on: February 06, 2019, 09:37:30 pm »
External trigger area, mysterious(no one measured it) cap under LMV7219
Is it on the other side of the PCB ?
