I add PHY LAN8700C, but it looks like it not have MAC address assigned - FF-FF-FF-FF-FF-FF. I'm not sure about pull up/down configuration of PHY. I made some reverse engineering of 2000x, 3000x and 4000x teardown photos, but it's not enough clear where pull resistors are going - probably GND. Now are 10k pull down resistors to RXD0, RXD1, RXD2, RXD3 lines. LED's are connected like in recommended schematic for MII mode - PHY application. I try to read M25P40 memory and also play with wire shark to check out communication.
LAN PHY detected.
EDeviceLoadEeprom, MAC address not programmed.
-EDeviceLoadEeprom 03:04:05:06:07:08
Phy found addr 31 (ticks=3327)
WaitForLink Start (ticks=3329)
No Link (ticks=4331)
<--EDeviceInitialize
GMAC DMA status register = 0x0
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
WaitForLink Start (ticks=6338)
Link Detected (ticks=6339)
GMAC Init : 100 Mbit/s FULL DUPLEX (MII)
Flushed Transmit Buffer
phyCfg->dwSpeed 0x64
phyCfg->bFullDuplex 0x1
GMAC DMA status register = 0x600004
DriverStart
GMAC Device enable interrupt
cable attached
Device load time:
NANDFLASH: 0 ms
SNANDFLASH: 0 ms
SHIM DLL, LoadRealDll [PalIO.dll] for [AgilentPalIO.dll]
SHIM [AgilentPalIO.dll] Get Process Addresses
LaunchInfiniiVision:
BLT Module Config 03 - UNKNOWN
