Maybe the resistors sets up the default configuration and it can still be modified via software. ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
My thoughts exactly, a user buys, say, the 70MHz version but upgrades it with keys to 100MHz (if that's an upgrade path that Keysight offer), somehwere down the line the 'EEPROM' goes corrupt or the user does a factory reset, the resistors set the 'scope back to 70MHz so the keys have to be input again.
The software will always be able to override the resistors, because it's the same software that reads the resistor voltage.
But as it stands I have a 200MHz 1000X on my bench now. I can even get it to 2.5GS/s with some issues that I'm reasonably confident are solvable.
Keysight don't sell a 200MHz 1000X series, so I've got extra performance thanks to a soldering iron
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Warranty definitely void!
I can set it to 50MHz, 100MHz, and 200MHz analog bandwidth and either 1GS or 2GS by twiddling resistor values. Haven't found 70MHz yet, although I found the boot option that displays that value. Video rendering tonight.
All that's needed for confirmation is to repeat the hack using the EDUX1102G
If you can get a US$650 2CH 200MHz bandwidth 2GS 1M scope with function gen for that price then it's going to be very popular.
