Author Topic: EEVblog #972 - Operating Chips Outside Their Spec  (Read 26027 times)
Offline EEVblogTopic starter
« on: February 15, 2017, 11:39:00 pm »
Dave tests the AD8436 True RMS converter chips inside the 121GW multimeter to see if it works well below it's voltage rail specification.
Bonus thermal testing in the chamber.
http://www.analog.com/media/en/technical-documentation/data-sheets/AD8436.pdf
Offline jfasoc
Re: EEVblog #972 - Operating Chips Outside Their Spec
« Reply #1 on: February 16, 2017, 04:29:50 am »
The whole video I was waiting for you to test how low it will work.
Offline nidlaX
« Reply #2 on: February 16, 2017, 04:38:11 am »
Can't wait to get one of these. I passed on the $200 U1252Bs so I can save my multimeter budget for a 121GW! :scared:
Offline KerryW
« Reply #3 on: February 16, 2017, 04:38:56 am »
Have you thought about using Batterizers with this meter?   >:D
One accurate measurement is worth a thousand expert opinions
- Adm. Grace Hopper
The following users thanked this post: JS
« Reply #4 on: February 16, 2017, 04:39:53 am »
Sorry, didn't occur to me to do that!  :palm:
Offline JS
  • Country: ar
« Reply #5 on: February 16, 2017, 05:33:15 am »
Dave, we all want a batteroo inside our meters instead of the low voltage operation!!  |O
JS
If I don't know how it works, I prefer not to turn it on.
The following users thanked this post: Caca
Offline integritetus
« Reply #6 on: February 16, 2017, 05:42:16 am »
I am curious as to whether Analog Devices will guarantee that the AD8436 will operate to its specifications at a supply voltage of 3.6 V, or whether they are saying that it works but the design user is on his own to characterize operation at voltages below the minimum 4.8 V.
Dave mentioned this his DMM design partner is doing testing.  I would expect that they could characterize some number of parts across voltage, temperature, and frequency, but I wonder how they would characterize the part across process variation (that is, the variation in process parameters for the IC process in which the AD8436 is fabricated).  I would expect that only the part designer/manufacturer could characterize the part across process (unless the design user were supplied with a significant number of parts binned by process parameter).
For a sufficiently small production of units, a design user could actually in theory characterize each part received.  But I suspect that is not practical for this project.
Offline kandrey89
« Reply #7 on: February 16, 2017, 06:27:29 am »
Is Dave making an EEVBLOG branded multimeter?
Is it branded only, or did Dave help design it?
Is there a pre-sale, spec page or something, can't find anything anywhere about it?
ETA and other details?
Offline tszaboo
« Reply #8 on: February 16, 2017, 09:13:03 am »
Some time ago: We were testing a FET driver. Specification said maximum voltage 18V. Sure we can go higher than that! They give large amount of headroom on these specs, and it will work fine at 20, if we want to.
Of so we started cranking up the voltage on the lab supply. At 18.3V the smoke flew out of the part  :o
Offline Supercharged
« Reply #9 on: February 16, 2017, 05:19:53 pm »
AM i the only one who saw a Wifi or Bluetooth module at 4:18?
Wireless Confirmed!
Science is about what is, engeneering is about what can be.
-Neil Armstrong
Offline NivagSwerdna
« Reply #10 on: February 16, 2017, 05:37:34 pm »
Firstly, I'm pretty sure those questions are answered somewhere on the forum.
Secondly, you just need to think about it for one second... just try and quantify the engineering required to have a decent product.  It's clearly going to be either a rebadged existing model or as has been suggested a rebadged exisiting model with maybe a tweak or two.  Personally I don't have any issue with that as its better to have a tool that works than a flakey v0.00001 of something.
But... I've been madly googling images and for the life of me I cant work out the manufacturer.  I'm was going on the basis that its got to be a reasonable manufacturer so that eliminates Hung Lo brands.  My line of search is working on the DMM glass.  It's likely that this model will have the same glass as an existing or planned model since an EEVBlog run will only form part of a larger commercial run..
Am I warm?  Any suggestions?
(If the price isn't outrageous I'll be getting one)
Offline testian
« Reply #11 on: February 16, 2017, 05:59:28 pm »
Definitely looks like one
Offline Len
« Reply #12 on: February 16, 2017, 10:20:14 pm »
https://www.eevblog.com/forum/chat/new-eevblog-branded-multimeter-coming/
DIY Eurorack Synth: https://lenp.net/synth/
Offline DavidDLC
« Reply #13 on: February 16, 2017, 10:22:29 pm »
Wireless Confirmed!
No you are not
Offline Brumby
« Reply #14 on: February 17, 2017, 06:26:52 am »
I think you'll find Dave's involvement is a bit more than that.
Dave has already done a (sort of) rebadge with the BM235 ... but the 121GW is something special.  :)
« Last Edit: February 17, 2017, 06:29:13 am by Brumby »
Online NiHaoMike
    • Facebook Page
« Reply #15 on: February 17, 2017, 06:59:21 am »
That part is rated to well above double the battery voltage and uses less than 1mA. Perhaps you could use a spare PWM on the microcontroller to drive a charge pump.
Switcher driver chips for mains applications often have an internal zener clamp to allow a simple resistor to supply startup power.
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #16 on: February 17, 2017, 09:42:40 am »
Hee Dave, is this what you were working on in #900 STM32 Development Board?
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline oldway
« Reply #17 on: February 17, 2017, 11:09:18 am »
Operating chips outside their spec is a bad practice, I don't agree with this.
Ask to the manufacturer to change their specifications....
The statement " the manufacturer (Analog Device) says it can work at lower voltage than specified" is not a profissional statement....It means that good working in this condition is not garanteed by the manufacturer of the chip.
You can't specify that your multimeter will work with 3.6V if the chip is only specified to work with 4.8V minimum voltage, that's not acceptable.
I worked in quality control and I would reject your multimeter....
Sorry Dave....
« Reply #18 on: February 17, 2017, 11:13:15 am »
Nope, and nope.
Nope again.
« Reply #19 on: February 17, 2017, 11:15:11 am »
You don't get a say in it :P
Apart from not buying it of course.
Offline oldway
« Reply #20 on: February 17, 2017, 11:17:30 am »
And what about using 1.2V rechargeable batteries ?
No way !
The only solution is to use 5 batteries instead of 4 or a 9V battery.
NB: 1.5V batteries often leaks, I have a Fluke 87 IV badly damaged by leaking 1.5V batteries....I never had such problem with 9V battery.
So I prefer using a 9V battery in a multimeter...
So I prefer a multimeter with a 9V battery....
« Last Edit: February 17, 2017, 11:37:34 am by oldway »
Offline f4eru
    • Chargehanger
« Reply #21 on: February 17, 2017, 11:20:20 am »
Question: why use a rms calculator chip?  I would rather use two adc channels and sample both I and U at the same time, and calculate the result. This way you can also measure power.
Also note that you don't need absolute add precision for your 6000 counts, you can use 12 bits, for example, the massive oversampling gives you the needed precision.
Concerning chips out site specs, it can be  OK,  if the risks have been properly rated, and the outside spec validated as thoroughly as possible. A eol test is a good bonus. I seen it done at a  big Corp for million automotive products. It was done properly.
« Last Edit: February 17, 2017, 11:26:09 am by f4eru »
Offline oldway
« Reply #22 on: February 17, 2017, 11:33:03 am »
I don't think Dave intend to make a multimeter as the Metrawatt Gossen Energy....
https://www.gossenmetrawatt.com/resources/tt/metrahit_energy/db_gb.pdf
It is far too expansive !
Even this multimeter seems to use two rms converter and not your solution, as max bandwith is only 100Khz.
« Reply #23 on: February 17, 2017, 11:46:26 am »
Because most multimeters use front end chipsets, and these integrate well with external True RMS chips.
It's not that cheap or easy to get fast decent 12bit converters and integrate them into the design.
It's much easier to use a proper True RMS converter chip that integrates into the measurement system nicely, can handle high crest factor waveforms, and can use the existing chipset converter and firmware.
And the meter is 50000 counts, not 6000 counts.
Offline f4eru
    • Chargehanger
« Reply #24 on: February 17, 2017, 11:48:39 am »
Expensive? Noooo, it's not! There are plenty of us today with integrated adc 12 bits or higher. Take one that is fast enough. The cost of the Micro is already included
