I've signed up for TronClub, I've been wanting to get back into electronics again. (Also Hello everyone!)
When I heard they were based out of Canada, I assumed that they'd be pulling the same trick that my VOIP provider does; primarily operates in Canada, but charges everything in USD. But as it turns out, it was $25 CDN for me. Score!
The only thing I'm not particularly happy with is the fact you can't set up both the beginner/advanced subscriptions easily on the site. Couldn't figure out how, and I wanted to get the microcontroller starter kit as well. But at least they will let you swap between the two series without issue; you receive whatever your next kit is in the chosen series, and they keep track of which kits you've received, so you shouldn't receive the same kit twice.
Once I get my first kit, I'll be flipping it to get the first micro kit as well.
