Author Topic: problems with links in code blocks  (Read 2659 times)
Offline FrankBussTopic starter
    • Frank Buss
« on: January 29, 2017, 04:17:26 am »
When I write this:
wget [url=https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin]https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin[/url]
git clone [url=https://github.com/themadinventor/esptool.git]https://github.com/themadinventor/esptool.git[/url]
cd esptool
sudo python2 ./esptool.py --port /dev/ttyUSB0 write_flash 0x00000 ../nodemcu_float_0.9.6-dev_20150704.bin
It automatically adds the url-tags, but because it is code, it shows the url tags, too.
When I use quote:
git clone https://github.com/4refr0nt/luatool.git
It adds the url-tags, too, but doesn't show it, which is fine. For code I would prefer that it doesn't change anything within the block. Is this possible? Maybe would be better to disable "Automatic Link Posted URLs" altogether, this would be an easy fix.
« Last Edit: January 29, 2017, 06:14:37 am by FrankBuss »
Online IanB
Re: problems with links in code blocks
« Reply #1 on: January 29, 2017, 04:22:20 am »
Let me try:
wget https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin
git clone https://github.com/themadinventor/esptool.git
cd esptool
When I preview the above, nothing gets modified. Is it only when hitting post that something gets changed?
If so, I would guess it is a bug. IMHO nothing inside code tags should get modified at all.
    • Frank Buss
« Reply #2 on: January 29, 2017, 04:25:54 am »
Yes, in preview it is right. And yes, it doesn't get modified here, strange. But it does get modified in this article: https://www.eevblog.com/forum/projects/how-to-setup-a-rapid-development-environment-for-nodemcu-and-lua-scripts/ It kinda works with quote instead of code, because then at least you don't see the url-tags.
Online IanB
« Reply #3 on: January 29, 2017, 04:30:03 am »
Well, I don't know what is happening to your posts. As you saw, no URL tags got added to my experimental post here.
    • Frank Buss
« Reply #4 on: January 29, 2017, 06:15:53 am »
Ok, I found the smallest working example for this bug:
First use a url-tag with a http address, then use a code-tag with a https-address, but without an url-tag. After posting, it adds the url-tag inside the code tag. Like this:
test.com.
[url]https://test.com[/url]
    • Frank Buss
« Reply #5 on: January 29, 2017, 06:17:03 am »
The forum code must be a mess for such kind of bugs :P
