A bit off topic, but while testing a 160W PV booster, I had EMC issues with an ancient Priority Electronics PE-008 , it was about 1.5m from the actual booster (running at 60kHz), down by the dummy load.
It was used for current measurement (but volts were just as bad) It would read off by a loong way (like 1/4 full scale), it was a pretty stable offset, but it changed when you moved the meter around or touched it, it was worse on the floor compared to sitting on a plastic bucket. Still showed a reading with leads unplugged and input shorted. I have a dozen or more other meters and none were affected, even the cheap ones.
