You could have skipped the analog part for showing what a scope is
I disagree.
By using the analogue scope, Dave was able to directly - and correctly - translate the measurement process from the single point-in-time (meter) to the continuous. In fact, after the DaveCad flip board plug-in, I would have liked a 15 second description of the spot and deflection process of an analogue scope. Certainly what followed made it the logical conclusion, but it was not explicitly clear. While a lot of people will have worked it out, there may be some who would have benefitted from that stepping stone.
The other thing is that I felt there should have been 5 seconds spent being explicitly clear on the need for a repeating waveform for a steady display.
However, once the analogue process was covered, then move on to the digital scope. I think Dave did this at the right time.
