Author Topic: Forced Taptalk on windows phone  (Read 3624 times)
Offline 1designTopic starter
« on: August 30, 2016, 01:42:54 pm »
I am having some trouble accessing the eevblog forum from my phone. It prompts me to use tap talk and refuses to load without it. Since I use a windows phone, Taptalk is not available. Nevertheless the forum keeps recognizing the device as Android. This started a few days ago and never happened before. Any idea on what to do?
BR
The following users thanked this post: kado
Offline vinicius.jlantunes
  • Country: br
Re: Forced Taptalk on windows phone
« Reply #1 on: August 30, 2016, 01:58:38 pm »
I have similar problems elsewhere sometimes where it thinks I'm on an Android too - have no idea how to resolve it.
However, just wanted to let you know that Tapatalk IS available for windows phone, I have it installed. Not sure if you want to install it or not, but it is available.
Offline Silveruser
« Reply #2 on: August 31, 2016, 02:32:25 am »
I've seen the same android thing. Tapatalk does work on Win 8.1 at least. Best of luck..
Offline darrellg
« Reply #3 on: August 31, 2016, 05:59:00 pm »
I get the tapatalk prompt too, but when I press cancel it loads the forum in the browser.
« Reply #4 on: September 02, 2016, 01:54:04 pm »
I run Windows 10, no matter what I do the page doesn't want to load, either OK or Cancel, neither do the trick. It seems I will have to give up on the forum from the mobile platform as Tap Talk is not something I wish to use.
Offline R005T3r
« Reply #5 on: September 02, 2016, 02:21:17 pm »
I have Android and it just work all fine. Running it from a Huawei P8, upgraded to marshmallow.
