Author Topic: EEVblog #910 - Indiana Jones Train Set Update  (Read 4570 times)
Offline EEVblogTopic starter
« on: August 12, 2016, 10:56:22 am »
An update on the Indiana Jones Train set.
Offline Brumby
Re: EEVblog #910 - Indiana Jones Train Set Update
« Reply #1 on: August 12, 2016, 11:52:09 am »
How about setting up the rocket sled as part of the narrow joining section?
The simplest arrangement being to just add another piece to the front of the existing section, maybe doubling its width, and build the rocket sled rails parallel to the train tracks.  Would have to move the 'operate trains' time switch back a bit.
Juts a thought.
The following users thanked this post: Silveruser
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #2 on: August 12, 2016, 12:45:03 pm »
Looks like you could do with a snake scope, there might be some hidden gems.   :D
« Reply #3 on: August 12, 2016, 12:52:23 pm »
Yeah, been meaning to get one of those.
Offline viila
« Reply #4 on: August 16, 2016, 01:55:34 pm »
If you can spare the space, I'd extend the narrow section where you made your cut so it's longer and then build the rocket sled track there like Brumby suggested. You could even build it so that the new section is an optional module so that the layout can be built like it is now, or with the extra section.
Something like https://dl.dropboxusercontent.com/u/17789257/indy.jpg
And if you make the rocket sled, you totally have to make it launch with a button!  ;D
