STM32 = Use TrueStudio!
I'm actually working designing µC PCBs and programming them using TrueStudio in the free version and it's great. No registration required, simply download and it's an eclipse based environment so supports standard plugins and the usual code navigation I love so much about eclipse. You can even get CubeMX as a plugin to run it inside TrueStudio
So yes, I'm a big fanboy of the CubeMX + TrueStudio combo!
Btw, the included FreeRTOS is awesome, too (freertos.org) and works a treat!
The Pro version offers some advanced features for debugging and code analysis but I've never needed any of those. Might come in handy for larger RTOS based firmwares.
Only downside to TrueStudio is that there is no (default) download and run button. All you an do is download and debug, so you have to stop debugging right away if you only want to download.
There is a way to fix it, though. Just let me know if you're interested.
So Dave (or anyone else), if you want to make your life easier, just use TrueStudio for your project
