But it will be unlikely to outperform a combination of an electrolytic and ceramic capacitor.
Yup, a hybrid approach, where a high-Q cap is dampened by a low-Q bulk cap, is best. This gives low impedance at all frequencies, from DC (where the supply regulator dominates), to mid band (where the bulk cap ESR dominates), to high band (where the ceramic chip's ESR and ESL dominates).
Usually a single larger electrolytic capacitor is use for bulk decoupling of many packages and to swamp out resonances of the higher Q ceramic capacitors. (1)
Usually, a bulk cap goes at the end of a chain of supply connections, where the chain is made of traces linking loads with bypass caps. It's a pretty safe topology, the ESL is easily estimated, and the required bulk cap C and ESR are easily calculated from that.
When the chains are single links only, it can be tricky. When would that happen? When loads are individually bypassed, and draw power from a plane pair. In some cases, it can be better to not use local bypass in this situation, or to use longer traces from bypass cap to plane (so that ESL is large enough that it can be damped with a bulk cap).
Some application notes recommend this for specific parts like wideband operational amplifiers and converters. I wonder though if these date from the time when through hole layouts were parasitic inductance was greater. (1)
Could be.
It does help if you use different sized chips -- ESL is proportional to length -- but you still must be mindful of damping, otherwise the worst-case impedance peak will rise above the required supply impedance, and you'll get spooky behavior at unlucky frequencies.
It is not quite the same situation but one project I did involved a 50 ohm high power capacitive ground isolator which operated from 50 MHz to 1.2 GHz. It ended up with 4 x 1000pF, 4 x 0.01uF, and 4 x 0.1uF surface mount ceramic capacitors in parallel using a symmetrical coaxial transmission line layout. Just using 4 x 0.1uF capacitors did not work at all.
Right. You needed 12 x 0.1 instead.
I don't understand the topology from that brief description, so it's hard to say which way is better. (The only thing you gain from using just 0.1's is BOM reduction, mind.) Obviously, it worked out well enough your way, and that's what matters.
This sort of thing has always bothered me. Why isn't the output from the power supply better controlled to limit surge current or dv/dt?
I don't think it's a thing you can control. Surge can't be limited, on the time scale of the capacitor; current is drawn from all other bypasses and bulk caps, before the controller can do anything about it. dV/dt should be fine with modern DC-DC controllers, as long as you aren't hot-plugging to the supply. Apparently part of the problem is that, tants crack over time, and self-heal, and that self-heal process draws a huge gulp from the supply. Which can cause random upsets! And, of course, an unlucky self-heal that runs away, results in an exploded cap...
So it's something that has to be used carefully, I guess preferably on small supplies or sub-nets. Fused caps can be used (that was an IBM thing, IIRC?). Overrated caps (2-3x voltage) is part of it, of course.
Where long life, reliability and uptime is required, ceramic chip + ESR resistor is preferred. The ESL isn't even any greater, if "wide body" parts are used.
(1) At some point it pays off to model the power distribution circuit and if you have the proper equipment, test it. I suspect this is either foreign or infeasible for many engineers leading to a mix and mash of various rules of thumb for decoupling which usually work but not always. Jim Williams had something to say about decoupling in Linear Technology application note 47 but unfortunately did not test any polymer electrolytic capacitors.
Yup. That we should be so lucky, that we work in a field where everything can be calculated and measured, if not always easily, but almost always with a hand-waving shortcut that is more than good enough!
Regarding polymers: they are simply low-voltage film caps. Same energy density, same time constant (i.e., ESR * C), similar ESL (again, proportional to lead length, so, the chip styles are better than the can styles). They don't leak current, or reform, like electrolytics do (at least, not as grossly), and they may self-heal (I've heard that some can, though the ones I've tested, failed shorted at about 120% of rating).
ESR is generally low, though a broad spectrum is available. About the same range is available between polymer and tant, with the tants clustering towards higher ESR (say 0.1 to 10 ohms), and polymers clustering low (say 10m to 1 ohm). There is plenty of room to shop around for ESR, in both types.
Since ESR is generally low, polymers can make things
significantly worse by shorting transmission lines, leading to reflection rather than absorption of waves.
They are of course an excellent choice for power supplies, where the low ESR is required for stability and low loss. This puts a very low impedance at one end of the supply, so that damping must be provided at the far end.
Or the supply must be designed with a low enough impedance throughout, comparable to the low ESR. This is how most VCORE supplies are constructed -- a handful of polymers at the start and end of the VCORE plane, and a ton of ceramic chips spread evenly inbeteen. Inspect a laptop motherboard some time, and see how the experts do it.
A good example where polymers shine, by themselves alone, is high power gate drives. Like IXDD614CI driving +/-15V into a big IGBT. A 100uF 35V poly across the power pins, is all that's needed to keep things happy! Notice this acts exactly like the ceramic cap across a TTL chip, just scaled down in impedance and speed (t_r ~ 20ns, easily 10 times slower), and up in power.
