Has anyone ever tried catching oncoming space debris with their hand while outside of the space station?
Not possible I believe, because anything in same height orbit as the astronaut would be going at the same speed as the astronaut. It's not like stuff is just darting around all over the place out there, all things in the same orbit must have the same speed. And if something accelerate then you must change it's orbit.
WRONG! Just because something is at the same level of an astronaut does not mean it is in orbit. I can be going a delta of anything from 0 kph to over 100s of kilometers per second. It could be a piece of rock passing by the Earth, or something in orbit around the Earth that was further than the moon at its furthest. Please, stop talking about space and astronomy if you don't know about it.
Yes, but we are talking about space junk in orbit around the earth. Always happy to be corrected, I'm not expert on it, that's why I said "I believe". Relax.
But yes, you are right, now that I think of it same height orbits can have different directions of course, so hence different directions and hence relative speeds to each other.
Orbital things mostly travel in the same orbital direction though do they not?
And no, I will not stop talking about something I find interesting, even if I am wrong.
The point I was trying to make is that (I believe, correct me if I am wrong), two objects at the same height orbit going in the same direction and path,
must be travelling at the same speed, yes?
Why don't you correct me on typical space junk then and answer the question. How likely is it that an astronaut can reach out and grab "space junk" (that has presumably been up there a long time, and essentially presumes the same orbit and direction?)?
I say not likely because it'll either be going to ridiculously fast due to some different orbital directional, or it'll be in different orbit entirely. i.e. how likely is it that random space junk "just floats by" the space station?
