Wow, that was a great video! Thanks Dave.
This is not my field, and it's been quite awhile since college physics, so I may have some really basic questions, but I would really appreciate learning more about this.
1) What is the ultimate purpose of using this giant machine to generate essentially IR, visible light, UV and X-rays, as opposed to say using an X-ray machine at the dentist's? Is it essentially the fact that you can get a much more energetic ("brighter") output? And that higher energy is necessary to perform the type of experiments that are being done there?
2) So I followed what they were saying that the beam attenuates (loses energy) due to non perfect vacuum, and more importantly due to the bending acceleration of the beam. So would that mean that a larger ring, with more subtle bends, would attenuate less? Or does it all come out in the wash because ultimately the beam has to bend a full 360 degrees anyway? (and thus the non-vacuum source of the attenuation would actually be greater in the larger ring)
3) Did I understand the beam timings correctly? The pulses are at a 2GHz frequency and each pulse is 23ps long? So in other words, a new electron bunch comes along every 500ps and are 23ps in "length" (giving a gap of 477ps?)
3a) In the scope display at 49:05, my understanding is that it was displaying a single beam measurement device, and each of the large "blobs" represented the electron bunches passing by the detector. But what is the gap? Is there an intentional "quiet" part of the beam with no bunches? Is this where new bunches are injected into the beam?
4) So when the main beam is tapped off for one of the experiments, I assume that one (or more) bunches of electrons are redirected off the main ring and into the experiment's beam line. Presumably these bunches would have to be replaced by new bunches to maintain the total ring current of 200mA. How is this managed? Are bunches stripped from the beginning (or end) of the pulse train and then injected at the opposite?
Fascinating stuff!
