Loading [MathJax]/extensions/Safe.js
Author Topic: EEVblog #834 - Wekomm Resistance Standard  (Read 26315 times)
Offline EEVblogTopic starter
« on: December 27, 2015, 03:53:07 am »
An impromptu play with Dave's Wekomm 10K Transfer Resistance Standard.
What is the strange discrepancy in drift on the graph on the Keithley DMM7510 multimeter?
http://www.wekomm.de/metrologie_e.php
This is Part 1
This is Part 2
Part 2 of an impromptu play with Dave's Wekomm 10K Transfer Resistance Standard.
Was the Keithley DMM7510 multimeter the culprit in the discrepancy in the thermal response?
Dave finds out with the help of a thermal chamber.
Offline Scottjd
    • YouTube Gadget Reveiws
Re: EEVblog #834 - Wekomm Resistance Standard
« Reply #1 on: December 27, 2015, 04:43:15 am »
I find this stuf fascinating also and some times go way down the rabbit whole with it.
I do wonder a few items.
What level is your lab on in the building? Just wondering about shops below you that keep the air/heat on higher that would force air up from other levels into your lab?
For the LCD of the meter, does it turn on and off?
I think this meter has a fan, could the speed of the fan change to compensate for the ambient air change as the fan tries to regulate the temp of the unit?
I could go on, their are so many factors to consider :)
I recently built a voltage reference and saw a difference of 0.00000 to 0.00010 and the bread board, turns out that was the ambient air temp change alone so I logged my lab temp and the data showed a 1.2C change despite the outside temp change of 13.9C. So not bad on lab temp.
Now I'm working on a cheap way to heat the refencse chip at 40C to keep I stable and still run long on battery.
Nice videos, gave me some other ideas. But my bench meter is a old HP 34401A calibrated 2 months ago so no internal fan to worry about I guess. This could be good and bad, presumably more good as long as I allow the 2 hour warm up first.
Please be sure to check out my YouTube channel and subscribe if you like the videos. https://www.youtube.com/c/GadgetReviewVideos
By people subscribing and giving thumbs up I know what I am doing is still wanted and adding value, then will continue to release new videos. Thank you for your support.
Offline pickle9000
« Reply #2 on: December 27, 2015, 04:47:54 am »
One thing I think people often forget:
- It doesn't have to be perfect, but does have to be good enough to get the job done.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #3 on: December 27, 2015, 08:18:43 am »
Yey, Dave using 7510, finally :)
Those banana wires could be causing some EMFs as well.
« Reply #4 on: December 27, 2015, 08:56:27 am »
Looking at the noise some screened leads would not go amiss, and connecting the guard to the ground of the precision resistor would eliminate a lot of the noise from the thermal chamber maintaining its set point.
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #5 on: December 27, 2015, 08:59:36 am »
Guard? There is no external guard port on 7510 AFAIK.
« Reply #6 on: December 27, 2015, 09:03:20 am »
Should have a grounding point, it is a precision unit and shielding does help a lot more than averaging.
« Reply #7 on: December 27, 2015, 09:14:23 am »
No it doesn't.
Offline classical
« Reply #8 on: December 27, 2015, 09:18:51 am »
Thank you for the fine experiment. It shows, how hard live is in the area of high precision and why the effort grows exponentially.
The "big" periodic changes during operation of the thermal chamber could be produced by the waste heat of the peltier cooler more than by the temp changes within the chamber itself.
The temp of the chamber was set to a temp below the room temp. So it has to cool a bit. And by cooling the poor efficiency of the peltier leads to a temp change of the heat exchanger on the back of the chamber.
And the Keithley is pretty close to the back of the chamber and potentially sucks in the waste heat of the thermal chamber.
So, we could have two "amplifications" to the disadvantage of the Keithley readings:
- The low efficienciency of the Peltier cooler amplifies the heat changes on the back of the thermal chamber
- The specified thermal coefficient of the keithley is bigger than the coefficient of the precision resistor. The Keithley potentially sucks in a part of the waste heat produced by the chamber and converts it by its bigger thermal coefficient to a bigger change in reading.
To improve this it could be helpful to set the temp in a chamber to a higer temp than ambient, so that the peltier has not to cool down so much. But maybe that the controller switches on the peltier anyway.
Socond improvement could bring a different local arrangement so that the waste heat of the peltier is not sucked in by the Keithley
Offline miguelvp
« Reply #9 on: December 27, 2015, 10:01:14 am »
It does seem the temperature chamber is not that stable for measurements at this range, even when Dave was showing the current temperature inside it was changing quite a bit and he did mention that it varies.
@11:48 he states the temperature chamber was at about 20C +-0.5C while he was monitoring it.
« Last Edit: December 27, 2015, 10:05:09 am by miguelvp »
Offline classical
« Reply #10 on: December 27, 2015, 10:07:01 am »
Yes, and if the temp inside changes a little bit, the temp at the backside of the peltier changes even more due to the low efficiency of the peltier.
Offline PeterL
« Reply #11 on: December 27, 2015, 10:36:13 am »
I like the small thermal chamber, I wonder where these could be bought?
Offline Bloch
« Reply #12 on: December 27, 2015, 10:47:25 am »
LOL not here. "All need at least 13 3/4 digits multimeter"  :scared:
Quote from: pickle9000 on Today at 03:47:54 PM
Offline miguelvp
« Reply #13 on: December 27, 2015, 10:49:05 am »
I think he modified a peltier based mini fridge like this one:
http://www.ebay.com/itm/Thermoelectric-Cooler-and-Warmer-Old-Fashioned-look-/221971503797
He did make a video, if I find it I'll link it here.
Edit: it was a thermal incubator (HERP Nursery II), related video:
« Last Edit: December 27, 2015, 10:53:03 am by miguelvp »
Offline PeterL
« Reply #14 on: December 27, 2015, 11:25:59 am »
Thanks, definitely gonna look in to that   :-+
« Reply #15 on: December 27, 2015, 12:28:07 pm »
Designed for Reptile eggs:
http://www.petsathome.com/shop/en/pets/lucky-reptile-herp-nursery-ii-incubator
Offline QXstuart
« Reply #16 on: December 27, 2015, 05:29:41 pm »
I bought an 'identical' ReptiPro 6000 a couple of years ago.  I replaced its on-off-on temperature control with a PWM controller with a tiny thermistor placed in front of the internal recirculating fan intake.  It now modulates the temperature to within +-0.05 C.
The PWM temperature controller I bought does require me to swap the output leads to the Peltier thermometric module. but it still cost 2x what the incubator/test chamber cost.
  Controller = TE Technology Model TC-48-20.     http://tetech.com/product/tc-48-20/
Offline Dr. Frank
« Reply #17 on: December 27, 2015, 06:09:31 pm »
Hi Dave,
very nice experiment and demonstration of the sensitivity of analog instruments in this ppm region..
Some remarks, though.
These measurements very obviously are extremely sensitive to any stray noise. Therefore, all disturbances you see, probably come from switch mode power supplies or from 50Hz mains.
The 400sec oscillations may be a beat frequency, if the temperature chamber strongly induces 50Hz mains, and if the 7510 does not measure (suppress) the line frequency exactly.
It may also well be an Alias frequency of the 8 sec sampling rate versus the 50Hz noise.
The 7510 (and other Keithley instruments) probably offer too few averaging possibilities. NPLC 100 (n/a for the 7510), with additional statistics averaging would be better.
Speculations about EMFs: The 7510A also has the Offset Compensation feature, which removes any EMFs.
It was not evident in the video, if this feature was switched on.
The cables are from multi contact, I assume? Gold plated contacts?
So the EMFs are probably very low, at least these are constant.
But there's another problem with these cables.
Their isolation is probably PVC, which resistance is too low, on the order of 1E10 .. 1E11 Ohm only.
As you have twisted the red and the black one, that already might cause errors of several ppm.
Better twist both positive and both negative ones and don't let black and red touch each other.
Or better use Teflon cables.
Frank
« Last Edit: December 27, 2015, 07:00:07 pm by Dr. Frank »
Offline kalleboo
  • Country: jp
« Reply #18 on: December 28, 2015, 09:06:06 am »
I spent the whole video wanting to peel off that screen protector... drives me nuts!
Offline tszaboo
« Reply #19 on: December 28, 2015, 09:11:00 am »
In the #835, you suggested to hook up a battery to the terminals to measure tempco for the meter.
So I'm just letting you know, that batteries have a voltage change for temperature change. The lithium cells I've tested had a few PPM/K, a magnitude higher than the 3458a used, but I've seen the change for FiFePO4 and lead acid. Maybe NiCd has less than noticeable change, but at 7-8 digit, the battery is not a perfect voltage source.
You should also take a battery around 50% charged, and let it settle for some time. And use good big cells, otherwise you will measure the 10 megaohm discharging the batteries and self discharge. Maybe for 6.5 digit.
Ultimately, I think batteries are OK for a few second transfer standard, but not suitable otherwise at this precision.
« Reply #20 on: December 28, 2015, 09:43:56 am »
Yes, I realised that was dumb after I uploaded it.
I've done a video on this sort of stuff:
« Reply #21 on: December 28, 2015, 09:44:35 am »
That's the idea  >:D
Offline Dinsdale
    • pretzelogic
« Reply #22 on: December 28, 2015, 05:19:06 pm »
How is you air-con physically delivered?
Maybe the "undershoot" when you start it up is the duct work warm air getting flushed out.
This can't be happening.
« Reply #23 on: December 28, 2015, 06:22:22 pm »
IIRC Dave has a split unit in his office, with a separate outdoor unit. No multi split, no central unit and ducting. The fan in those has a very short run from the evaporator to the room, so not likely. The undershoot is probably a temperature differential or a cable thing, or a mains induced artefact with the drop in supply voltage with the unit turning on.
Time for Dave to look out for one of those older ferroresonant power conditioners, which provide both short term dip ride through and very good spike and noise filtering, in addition to the voltage regulation. The higher third harmonic and the increased line reactance are a bonus, helping to reduce the current spikes through the SMPS input diodes for those units without active PFC, and even for active PFC they will reduce radiated noise down the line.
Offline HighVoltage
« Reply #24 on: December 29, 2015, 02:01:55 pm »
Very nice video, Dave!
Great to see the Keithley 7 1/2 digit meter in action.
May be part 3 could be the same setup with the Keysight 34470A 7 1/2 digit meter in comparison.
Interesting also, that the Keithley meter 7510 does not have a guard, like the 2450 SMU.
« Last Edit: December 29, 2015, 02:05:16 pm by HighVoltage »
