No shielding
Is there really no metal shielding in this scope, like you have in the Rigol and Siglent scopes?
In the Rigol and Siglent scopes, the shielding is massive, and you have to take it out, to even see a glimpse of the PCB board.
Also no shielding for the PSU itself. Why haven't they looked at Rigol and Siglent?
While the front-end input channels have shielding on the top PCB board, there is no shielding on the bottom of the PCB board for the front-end input channels? Is this really okey?
This scope looks like a toy, without any shielding!
Xilinx Zynq XC7Z010 evaluation board
Could it actually be that they just tossed in a standard Xilinx Zynq XC7Z010 evaluation board in this scope?
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
That could explain why they did not have a single PCB board! Are there any reference numbers on the processor board? I could recognize DS16P02A in the video, but there might be other reference numbers on it.
Taiwan versus China
What happened with Taiwanese companies delivering better quality than Chinese companies?
The way it is put together, with missing screws, and plastic posts that are not fixed at the other side.
It seems that they have put this scope together in a similar way like the Eastern European Trabant car
