Author Topic: EEVBlog #815 - Mailbag Teardown Bonanza  (Read 19864 times)
Offline EEVblogTopic starter
« on: November 10, 2015, 10:22:23 pm »
A Teardown Bonanaza Mailbag!
Fran Blanche: https://www.youtube.com/user/ContourCorsets
SPOILERS:
Lightsaber
Chinon Genesis II Film Camera
Morrow Apollo Aircraft GPS
Morrow Apollo LORAN Navigation Receiver
1970's 300A Navomatic Analog Autopilot
Thrane & Thrane GSM Satellite Phone
Offline max666
  • Country: at
Re: EEVBlog #815 - Mailbag Teardown Bonanza
« Reply #1 on: November 10, 2015, 10:48:21 pm »
I don't understand the issue with the inward curved keys of the Spectrum+, aren't practically all keyboards made that way?  ???
Offline c4757p
  • adieu
« Reply #2 on: November 10, 2015, 11:04:49 pm »
Yes, even my beloved IBM has a slight concave. I don't think that is what's wrong with the keyboard, I think it's more the small effective key size (they've got those little round circles instead of using the entire key). It really does look like an awful keyboard.
Offline g.lewarne
« Reply #3 on: November 10, 2015, 11:16:57 pm »
The separate camera teardown video is marked as Private
Offline Don Hills
« Reply #4 on: November 10, 2015, 11:49:36 pm »
The Spectrum keyboard doesn't use conductive rubber contacts. There are 2 sheets with metallic contacts printed on them, facing each other but with a separator sheet between them. Pressing a key pushes the contacts together.
The original 40-key board had a single such sandwich, and for some characters you had to press and hold one key then press another. On the + keyboard, the contact sandwich was "double decker". Some of the common double-key combos were mapped to single keytops. Pressing the key would press the stacked sets of contacts in the correct sequence.
Offline Deathwish
  • Country: wales
« Reply #5 on: November 11, 2015, 12:10:45 am »
Wot ! no SWMBO or Sagan appearance ????, quality is defo going downhill :P
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline crispy_tofu
« Reply #6 on: November 11, 2015, 12:26:51 am »
I see your weirdly-designed keyboard and I raise you mine!  ;D
Offline cpuerror
« Reply #7 on: November 11, 2015, 12:31:39 am »
Good video but I would have liked to see those avionics powered up.
« Reply #8 on: November 11, 2015, 02:03:04 am »
Slightly. It's more a combination of the deep curve and the shape. You have to feel it to get the sense of crappiness.
« Reply #9 on: November 11, 2015, 02:04:39 am »
If nothing else the concave curve may help reduce glare from overhead light reflections. Flat keytops seem to be a very contemporary fashion though. My laptop and bluetooth keyboard have flat keytops.
My logitech has slight concave tops in the X direction, flat in the Y.
Offline max666
  • Country: at
« Reply #10 on: November 11, 2015, 02:09:21 am »
Ah I think I understand now. The Spectrum+ has spherically concave key-caps, while modern keyboards usually have cylindrical concave key-caps, like you said "concave tops in the X direction, flat in the Y".
Yeah I can see how that might weird one out.
Offline crispy_tofu
« Reply #11 on: November 11, 2015, 06:10:38 am »
I was searching for those data cards and it looks like Garmin still sells Garmin USB Data Card Programmers, but for the newer 'legacy' models with an LCD.  :-+
« Reply #12 on: November 11, 2015, 06:24:00 am »
Yeah, cylindrical concave is a better term.
The full concave really feels weird.
Offline Howardlong
« Reply #13 on: November 11, 2015, 06:53:02 am »
The patch antenna array voodoo: four patches, each fed at two points at 90 degrees, with a 90 degree (1/4 wavelength) phase shift delay made out of PCB track microstrip transmission line thus producing circular polarisation.
To maintain the right impedances, there are a bunch of 1/4 wavelength transmission line transformers, i.e., 1/4 wavelength lengths of different width PCB tracks on top of the ground plane making various different impedance microstrip transmission lines: you could use several pieces of 1/4 wavelength different impedance coax lengths if you wanted to, a transmission line is a transmission line, but it's easy and cheap to fabricate on a PCB together with the antennas. The transmissions lines are not designed to radiate, just the square patches are meant to do that!
By using a 1/4 w/l transformer, you can change the impedance in a reasonably loss free way.
For example, say you have two 50 ohm antennas you want to feed from a single 50 ohm source, if you just parallel them up you end up with 25 ohms. But by placing a 70.7 ohm 1/4 w/l transmission line in front of one 50 ohm antenna, it will look like 100 ohm. Do that twice, once for each antenna, and parallel the fwo 100 ohm presentations together, you get a single 50 ohm presentation. Bingo!
The 70.7 ohms comes from Zt = sqrt(Z1 * Z2) where Z1 and Z2 are the impedances you want to transfer from and to, and Zt is the impedance of the 1/4 w/l transmission line required. So in the example, Z1=50, Z2=100 so Z2=sqrt(5000) = 70.7 ohms.
Now, the velocity of the wave on PCB or any substrate isn't as fast as in free space. The velocity is c/sqrt(Er), so say for FR4 with Er approx 4, the velocity factor is about 0.5, so the length of the 1/4 w/l microstrip lengths would be about half that had they been made in free space.
To figure out the impedances of the transmission lines, predominently it's calculated from the width of the track, height above the ground plane and the permittivity (Er). 50 ohms is about 3mm on 1.6mm FR4, there are on line calculators for this.
FR4 might be OK to L band which this antenna looks to be judging from the size, but it becomes quite lossy much higher in frequency.
Edit: Why the foam? This is a physical mechanical separator between the patch antennas and the plastic enclosure. Because the foam's mostly air (Er=1), it won't detune the patch antennas and transmission lines, which a very close proximity plastic enclosure would do.
« Last Edit: November 11, 2015, 07:09:23 am by Howardlong »
Offline max666
  • Country: at
« Reply #14 on: November 11, 2015, 11:10:51 am »
Damn, awesome post! Thanks for unavailing some of the voodoo magic, Howardlong.
I learned and understood so much more about RF just by reading your short post.
Offline sbprojects
    • SB-Projects
« Reply #15 on: November 11, 2015, 12:37:00 pm »
If RHCP means Left Hand Circular Polarised.
What would be the abbreviation for Right hand Circular Polarised?  :)
Offline Fungus
« Reply #16 on: November 11, 2015, 12:50:46 pm »
At least they have a cutout at the top for long fingernails...
Offline AdamCooman
« Reply #17 on: November 11, 2015, 02:01:48 pm »
Very nice video, I always like the two-minute teardowns, especially when there's RF stuff involved.
The power amplifier in the satellite phone is a three-stage amplifier (see attached image). The RF chip you were indicating is actually just the second stage. The big power is delivered by the final module underneath the metal bar.
I really like their design. Would it be possible to provide some high-res photo's of that PCB, I'd love to study the whole transceiver module some more. (I don't really find a mixer. could that one be on the main board?)
Offline @rt
« Reply #18 on: November 11, 2015, 02:45:50 pm »
I would have liked to see the Loran and GPS receivers powered up on the bench even without antennas
(but preferably with them), or even just that old GPS module on it’s own.
« Reply #19 on: November 11, 2015, 04:44:12 pm »
The autopilot brings back memories. The 1458 will be doing AC amplification, with the 4016 analogue switches being used as synchronous demodulators to detect the peak of the AC signal from the sensors that are all running from 26VAC 400Hz. The 741's will be DC amplifiers, with the one pot being used for a slight gain trim in the feedback loop, compensating for the sender being slightly variable in amplitude, and the zero will be doing an offset trim on the 741 to compensate for errors in the synchronous detectors and the opamp itself. The opamps will be selected devices, a sort during production for those with the lowest popcorn noise.
The later stages will have integrators ( big  wet slug tantalum capacitors being used as integrator caps, a foil unit is bigger than the whole unit in the value needed) with the 4016 being used as switches to connect the input samples to bias the integrator and another part being used as a zero clamp to disengage. Simply does heading control to keep you aimed to a waypoint, and you simply select it by a bearing.
Offline Jr460
« Reply #20 on: November 11, 2015, 06:27:31 pm »
I don't think you are going to see that autopilot module running on 400Hz AC.
That model, what is known as a single axis model/wing leveler, was popular in small Cessnas.  Think about a 172 or 182.  (I may have even flown a 172 that had one, but I never engaged it.)  Everything on those planes is 24VDC, no AC power.
Link that gives a lot of info.  http://www.mtnflyers.com/assets/Cessna_ARC_Navomatic_300a_Blue_Highlight.pdf
(Just sold a Piper Arrow that had a two axis AP, and an HSI.  That was a joy to use, it would even capture and follow the glide slope on an ISL approach)
Offline Howardlong
« Reply #21 on: November 11, 2015, 07:49:06 pm »
I was in a bit of a hurry to get out this morning when I wrote my original post above, I've since spent some time looking into this in a little more detail.
The power splitting is achieved with a cascade of 35 ohm 0.25 w/l  transformers taking 50 ohms down to 25 ohms, and then paralleling up the next two 50 ohms.
At each antenna, there are two feedpoints phased 90 degrees apart for circular polarisation each with an approximate impedance of ~25 ohms. These are transformed up to about 100 ohms with a 0.25 w/l transformer of about ~50 ohms. The resulting two 100 ohm feedlines are paralleled up to make 50 ohms and feed back into the remaining cascaded power splitters.
The additional 0.25 w/l delay in two of the 50 ohm sections is because two of the patches are being fed at different corners to the other two, an phase needs to be maintained on the wavefronts emitted from each antenna or you'll definitely not get the desired directionality and gain (think about the constructive interference pattern we're after to achive gain).
On reflection, I had missed in my haste the four parasitic copper director squares in front of the patches separated by the foam which provide more gain and directivity. The foam is there to maintain mechanical distance for the desired beam pattern. A side effect of the parasitic directors is that there will be a significant lowering of the feed impedance of the directly driven patches.
« Last Edit: November 11, 2015, 08:03:16 pm by Howardlong »
Offline max666
  • Country: at
« Reply #22 on: November 11, 2015, 08:28:49 pm »
So, what's going on with the 4.7 kOhm resistor in series with the backup battery?
Offline martinc
« Reply #23 on: November 11, 2015, 09:51:36 pm »
Hi Everyone, I'm Martin. I sent in the aircraft avionics which were shown in this episode. I'm a former commercial pilot, flight instructor, aircraft mechanic, and electrical engineer (ME EE). AMA!
Offline martinc
« Reply #24 on: November 11, 2015, 09:57:57 pm »
My totally random guess is that it serves as a current limiter for when the device is being serviced. The voltage drop across the 4.7k resistance is probably negligible for whatever currents the hardware which uses the backup battery draws. But when some traces are shorted out when someone is poking around in the case then the resistor limits the current to less than 1ma.
« Last Edit: November 11, 2015, 09:59:45 pm by martinc »
