Author Topic: Teardown of an X-Ray machine, quite old video ?  (Read 10148 times)
martinr
  • Guest
« on: October 24, 2015, 08:27:58 pm »
I was browsing Dave's YouTube channel for a teardown video I remember he made, it was some kind of x-ray machine I think and he at some point was pouring out this gross looking oil from parts of it. Can't find it, I remember it was quite fun, it was a long time ago so maybe it was removed.
Anyway, greetings to all and thanks for any clue.
martinR
Offline PA0PBZ
Re: Teardown of an X-Ray machine, quite old video ?
« Reply #1 on: October 24, 2015, 08:38:01 pm »
I can't remember Dave ever doing that, but the one that comes to mind is this:
Offline hamdi.tn
  • Country: tn
« Reply #2 on: October 24, 2015, 08:52:31 pm »
you mean mike video ' mikeelectricstuff'
Offline PA0PBZ
« Reply #3 on: October 24, 2015, 08:54:00 pm »
Maybe, but I went for the oil pouring...
Offline Andy Watson
« Reply #4 on: October 24, 2015, 09:03:19 pm »
I remember a video where somebody tore-down a big, oil-filled x-ray transformer - required lifting equipment to take it a part. I think it was one of the "maker" community that made the video. Chris Boden maybe?
Edit: This is the one I was thinking of:
https://youtu.be/gZtSE6OJGBc
« Last Edit: October 24, 2015, 09:31:16 pm by Andy Watson »
martinr
  • Guest
« Reply #5 on: October 26, 2015, 01:56:50 am »
Thanks a bunch guys, those were some really interesting videos in themselves, definitely worth a view. But not what I remember. The video I remember was Dave for sure, I guess he was in his old garage lab as I doubt he'd want to go pouring out oil in his nice new clean lab with smart carpeting.
I'll keep ploughing through the older videos and see if it is hidden somewhere. If it wasn't Dave then it really is a case of my memory playing tricks!
Thanks again for the replies, nothing like a mystery from far back in one's memory  ;)
Offline promacjoe
« Reply #6 on: October 26, 2015, 02:27:07 am »
 Note: if you ever find an x-ray machine and want to tear it down, do your homework first. Some of the old x-ray machines contain a radioactive powder. One such machine contaminated several blocks, and affected hundreds. I don't remember where it happened, but I believe it was India. it was a documentary on the PBS channel.
Be Careful.
Offline helius
« Reply #7 on: October 26, 2015, 02:33:37 am »
X-ray machines do not become radioactive. The X-rays are produced by scattering when high-velocity electrons in a vacuum tube hit a target. The greatest danger when handling these machines is if the safety interlocks are defeated, or the beryllium window in the tube is broken releasing beryllium dust.
You are thinking of incidents when radiotherapy machines (which are made for treating cancers, not for imaging) were broken into, releasing their radioisotopes.
https://en.wikipedia.org/wiki/Goiania_accident
Offline amyk
« Reply #8 on: October 26, 2015, 03:08:16 am »
Mike's x-ray machine teardown does contain oil-pouring.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #9 on: October 27, 2015, 07:50:35 am »
Pretty sure Dave has never done an X-ray video.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline rickselectricalprojects
« Reply #10 on: October 27, 2015, 08:09:52 am »
i would love to get my hands on an xray transformer >:D but its probably best that i don't get one.
Offline crispy_tofu
« Reply #11 on: October 27, 2015, 08:13:40 am »
Yep - to my knowledge, he hasn't. Would like to see one on the blog though!  :popcorn:
Don't lick it!  :-DD
Offline Nermash
« Reply #12 on: October 27, 2015, 08:28:16 am »
You might be thinking about Photonicinduction's video on repair of one of his HV transformers?
Offline dr_dan
« Reply #13 on: October 27, 2015, 02:16:27 pm »
Be Careful.
Are you thinking of this (actually a radiotherapy source):
https://en.wikipedia.org/wiki/Goi%C3%A2nia_accident
« Reply #14 on: November 05, 2015, 10:59:15 am »
Don't lick it!  :-DD
if you licked that:
there might be a slight chance you would die :-DD
« Last Edit: November 05, 2015, 11:01:23 am by rickselectricalprojects »
Offline Psi
« Reply #15 on: November 05, 2015, 11:12:12 am »
Another thing to worry about is if the oil contains PCBs  (not circuit boards).
It's really nasty stuff.
« Reply #16 on: November 06, 2015, 04:00:08 am »
what exactly are PCBs?
i see capacitors from microwaves and start caps that say "no PCBs"
Offline SNGLinks
« Reply #17 on: November 06, 2015, 04:07:12 am »
https://en.m.wikipedia.org/wiki/Polychlorinated_biphenyl
Offline helius
« Reply #18 on: November 06, 2015, 04:25:22 am »
They were used in transformer oil for their dielectric and nonflammable properties. Preventing corona breakdown and arc fires in HV transformers is a very good thing. Pity about the health effects.
