Author Topic: EEVblog #133 - Dodgy Digikey Components  (Read 20480 times)
alm
  • Guest
Re: EEVblog #133 - Dodgy Digikey Components
« Reply #25 on: December 16, 2010, 11:42:06 pm »
Some were off by more than 1% IIRC, so I wouldn't put much trust in the markings. They aren't 10ohm, 0.1%, that's fairly certain. No one (except possibly Bourns) knows what they really are, so I would assume the worst, and not simply 10.13ohm 0.1% (or whatever the measured value was). Tempco can be anything, they could even be high TC resistors designed for TC compensation (if they make those in these sizes and values).
Offline Icchan
« Reply #26 on: December 17, 2010, 01:30:30 am »
This just shows how important testing can be even in small batches of components/products. But what I really liked in this episode was that this one had a real problem and to solve that, Dave showed many basic techniques for finding, measuring and solving the problem. An inportant lesson for any  EE out there :)
« Last Edit: February 19, 2014, 02:24:37 am by Icchan »
E.L.Brown
  • Guest
« Reply #27 on: December 17, 2010, 01:37:41 am »
This is exactly why i check every single part with a tolerance rating below 1% when it arrives at my place  ;)
If you want 0.1% or better , you want it for a reason . . .
Trust me - the extra 10 minutes are worth it !
Offline Psi
« Reply #28 on: December 17, 2010, 01:52:39 am »
So you're trying to avoid the following...
Quote from: E.L.Brown
Unbelievable that this little piece of junk could be such a big problem.
Offline EEVblog
« Reply #29 on: December 17, 2010, 02:09:01 am »
I ordered the same part from Digikey to build my own uCurrent, P/N: CRT0805-BY-10R0ELFCD-ND, date on my packaging is 16-Nov-2010.  I measured a couple of resistors in my batch using my Agilent U1253A and they were 10.12 and 10.13, so I suspect that the parts I have are from the same reel.
I haven't contacted Digikey, but will be interested to know the outcome of Dave's investigation.
Thanks for the confirmation. Yes, likely the exact same reel.
I now have the replacements and will measure when I get home.
They are the exact same type and part number, but Digikey have assured me they have tested them and they are within spec.
Bourns have also requested one of my uCurrent's so they can analyze further in their Taiwan facility, and the left-over parts I have too.
How that is going to help them is beyond me, they have a whole bloody reel of parts, and my uCurrent is irrelevant!
Dave.
Offline Jimmy
« Reply #30 on: December 17, 2010, 04:08:02 am »
Maybe they will copy it and put it on the market
Offline Fraser
« Reply #31 on: December 17, 2010, 10:16:29 am »
Dave.
May be they want to fully understand the implications of their 'out of tolerance' component on your design and the work required to correct it.... Financial Compensation assessment  ? Canon had a major reliability problem with some Sony CCD chips that they used. They repaired my Camcorder when it was over 5 years old....Sony had to pick up all associated costs for all such repairs including postage and labour.
Offline allanw
    • Electronoblog
« Reply #32 on: December 17, 2010, 10:29:24 am »
Haha, that's easy enough to do already considering Dave has published full schematics and layout and even described the entire design process in a video.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #33 on: December 17, 2010, 10:49:12 am »
Dave.
My guess is that it's standard procedure to look at the customer's design to eliminate the possibility that the  application is not causing problems running parts out of spec. Current-sensing R's can be subject to all kinds of abuse, and users won't necessarily understand the limitations of the parts they are using.
 They probably haven't looked at the ucurrent design in any detail.
As regards testing, for a test instrument like this, I'd suggest that the minimum production test really should check zero and full-scale accuracy on all 3 ranges, as apart from the unlikely chance of bad parts, more common things like bad solder joints, PCB faults and wrong components can easily happen.
A full functional test pretty much eliminates the need for testing parts, as any part issues will surface.
Day Job: Mostly LEDs
Offline EEVblog
« Reply #34 on: December 17, 2010, 11:08:57 am »
No need for that when Digikey have confirmed they have found reels that are out of spec.
That's exactly what I do.
Dave.
Offline Neilm
« Reply #35 on: December 17, 2010, 06:12:48 pm »
They will also check that the customers process has not caused any of the problems - for instance the soldering might have been done at too high a temperature, or been held at that temperature too long. I once had a problem with an IR transever - they would work in the factory but fail prematurely. After sending off the boards from both failed units and boards just assembled, the supply came back with the conclusion that the unit was being damaged by the assembly process, but for some reason some were fine, other were not. It turned out that the failed boards had been reworked to fix minor faults. When that happened a soldering iron was held above the transever - it focused the energy onto the detector and damaged it. The fix - ensure they were covered up prior to any rework.
Assuming that it doesn't have a wierd error curve that puts it out mid range.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #36 on: December 17, 2010, 06:17:07 pm »
Neil
True, but assuming the design itself works OK, a manufacturing fault causing mid-point errors is pretty unlikely. Except possibly  a stability issue, e.g. oscillating under certain conditions.
Offline Bored@Work
« Reply #37 on: December 17, 2010, 11:03:24 pm »
When you give them the left-overs they have the evidence and you have nothing any more. And then suddenly the evidence disappears.
Offline Neilm
« Reply #38 on: December 21, 2010, 07:23:19 pm »
When I sent off the IR transceivers I got back a whole series of X-ray pictures showing the receiving circuit of the various devices. It was that which allowed us to work out what had happened – instances of boards that had not been reworked were substantially less than non-reworked.
Neil
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #39 on: February 04, 2011, 08:46:28 pm »
sorry for bumping this. but i got reminded when eetimes emailed me. here the link to bulk resistivity test (but i'm not sure what they mean by bulk), i thought how to measure massive amount of resistors, but turned out not be like that. but might useful to others (might not), check the linked pdf, adios:
http://www.eetimes.com/design/test-and-measurement/4212791/Measuring-the-resistivity-of-bulk-materials?cid=NL_TestMeasurement&Ecosystem=test-and-measurement
Offline MBY
« Reply #40 on: October 19, 2011, 08:09:33 am »
Sorry to bump this thread once more. But I tried to watch episode 133 again but something has happened.  The #132 and #134 works, but it seems that the file for episode #133 is missing?
Offline EEVblog
« Reply #41 on: October 19, 2011, 10:47:31 am »
Wow, so it is, no idea why.
Fixed.
Dave.
Offline MBY
« Reply #42 on: October 19, 2011, 02:08:40 pm »
Great! Good episodes is always worth watching at least twice! :)
Offline pascal_sweden
  • Country: no
« Reply #43 on: November 01, 2015, 11:42:46 am »
Maybe that company has to change their name into Dodgykey :)
