Yep, Ex series 'ASCO' chassis bolted into a bench case. Not even a new metal chassis used. Not what I was expecting. Microbolometer is standard type fitted to Ex series. Not Lepton core (thank goodness) as that is currently limited to 160 x120 pixels or less. This is a classic case of repurposing a current production item to fill a specialist market role at the lowest possible retooling cost. Hence the little USB extension cable !
It would have been better if they had used the Exx chassis as the basis of this unit. Manual focus lens plus touchscreen. A better camera chassis in all respects. Even the Ex chassis could be made manual focus if FLIR had wanted such. It is, after all, just the modification of a plastic lens holder.
Video mentions Germanium lens. On these cameras a Calcogenide glass material lens is used as it may be moulded and is cheaper.
Fraser
