Let me know, I'll be glad to answer anything I can remember.
I have many questions but they will be out of topic here. ;-)
Just a quick one, when you work in a power station, are you busy all time or just letting the computers do their job and waiting for the next incident?
Just to keep it on topic. I did build a digital clock when I was about 11-12 years old, mid 1970s. Based on one of those fancy all-in-one clock chips.
Computers, even in the newer units of the time did nothing in terms of running a unit. The computer downtown, a PDP/11, sent commands to the tribune control to bump up or down the power set point. But one push of a button on the controls and the turbine was all local, and would either stay at the load set, or follow the load. The control systems took care of fuel feed rates air dampers, valve settings, etc. I suspect that even new units, the control systems might get some "assist" from a computer, but can keep things running just fine without one.
(Sorry to ruin it for all folks that think a hacker on the inter-webs can take over power plants.)
If all the computers were dead everywhere, then the units would run, and follow the load. You wouldn't have adjustments for 24 hour freq. control, and you wouldn't get the best mix of loads across units for fuel usage.
The plant I worked at started with two units in 1917, those where gone by the time I got there, and that space was used by one of the newer units. Two more units were mothballed. Ripping out all the asbestos would have cost a lot, and the space wasn't needed at that time. The next newest unit was built in the 1950, the next in the 1960, the next in the early 70s, and the newest in the late 70s. That plant is still running. I can tell from the outside that have added to the two largest units SOx scrubbers. I suspect the oldest unit that ran when I was there has been shutdown. It was designed for lower operating pressures, thus was not very efficient.
The oldest running unit had a very basic control system. Lines from the control room to the plant were all pneumatic. The two newest ones each had a room with about 24 racks full of analog controls for the turbine and boiler. They may have had some 7400 type logic chips. No one ever touched that stuff expect for once a year when the unit was down, techs from the respective manufactures would come in and help tweak and align the feedback controls.
Back to your basic question. The "operations" staff were the guys that sat in the control rooms. If everything was fine, they sat around and waited for something to show up on the panel. If a unit's load went way down, they might have to shutdown a coal mill, and then later start one back up. That required someone to follow a procedure to start motors and change valves, and light off the burners from that mill. Sometimes going out into the plant and cranking something open or closed. Full unit startup and shutdown, they were busy as hell and you stayed away from the control room and out of the way. I think it was requirement that you were a member of the local biker club to be in operations.
"coal yard" was busy all the time, got to keep getting coal out of the barges. The "maint" department always had someone in the plant, with most of them being in on the day shift. Something always needed fixing. I think they had the most people of any department.
"Instruments and Controls" was always busy with scheduled work. They would pull sensors on a schedule and bring them back in and calibrate them. Service all the chart recorders, file/catalog the charts.
I was mainly in "Tech Srvcs" We had the lab. Coal was analyzed, boiler water chemistry was monitored and adjusted. We did the engineering for new projects, did all the efficiency studies. Adjusted the feed water heaters and the electrostatic ash precips.
The precips might be fun for Dave to see. Big hockey puck SCRs and control that are fast to detect and ramp back power before an arc can jump between the wires and plates.
Other than that it was few office people, management, cleaning staff, etc.
