Quote from: coppice on July 17, 2015, 01:25:43 pmDoes anyone make a genuine cordless personal static dissipater? Some type of body worn ioniser, perhaps?Is the atmosphere grounded? (Genuine question)
I have socks on carpet in my room when I work on electronics. Could you test the foot rub test with socks as well to see what voltages you get?
Never stood on an IC, can't imagine it being worse than standing on lego though.
Maybe cordless means "supply your own cord"? Lost in translation?Else, why even bother with the 1meg resistor? Save production costs and leave it out...
Quote from: PGrant on July 17, 2015, 01:36:22 pmNever stood on an IC, can't imagine it being worse than standing on lego though.14 little razor blades > 6 blunt plastic bumps.
Quote from: dadler on July 17, 2015, 06:29:15 amMaybe cordless means "supply your own cord"? Lost in translation?Else, why even bother with the 1meg resistor? Save production costs and leave it out...That what I was thinking too. Something is lost in the translation. Why add that screw to the resistor? It looks better without it, so it clearly has some purpose other than looks.
Huh, so it doesn't work? Now there's a shocker! Thanks for the video Dave! Next up: Directional cables!
Quote from: zapta on July 17, 2015, 02:50:17 pmHere is the prototype of my invisible wristband. Will start taking orders soon.Do you have them in other colours?
I can see one possible use case for this thing: When walking around the office (pvc floor) in the winter (very dry air) one can built up a quite a lot of charge. So much in fact that it is rather painful to touch any earthed object. (big metal objects are also an option even when not earthed) In that case one could touch the screw on that strap to the nearest earthed object for a non-painful discharge.
Quote from: John Coloccia on July 17, 2015, 01:46:52 pmThat what I was thinking too. Something is lost in the translation. Why add that screw to the resistor? It looks better without it, so it clearly has some purpose other than looks.Agreed - maybe there's supposed to be a cord and connector attached to the screw, but they ran out of them or this is an "unfinished" item intended to be assembled to a cord.
I had a strange thought. What kind of queries would bring up this pic on Google images?
What I find amazing about this product, is the idea that anybody could fall for such a obvious scam.
Quote from: AF6LJ on July 17, 2015, 01:52:54 pmWhat I find amazing about this product, is the idea that anybody could fall for such a obvious scam.Is it obvious?I'm not sure if such a thing is possible or not. I can imagine a battery powered device that generates opposite charge to the one at your wrist in order to cancel it out. I don't know how you'd go about making it, but I can imagine it.(Wrist-mounted Van-Der-Graaf generator?)
Try: "arm and hand"
