Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
EEVblog
EEVblog Specific
X-Carve Live Build 4 -> Re Terminal Blocks vs Stranded wire
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: X-Carve Live Build 4 -> Re Terminal Blocks vs Stranded wire (Read 3165 times)
Asmyldof
Regular Contributor
Country:
Freelancer - Persnicketist - Do'er of stuff
on:
August 04, 2015, 01:10:59 pm »
Dear Dave2 / SpareDave / DaveBackup,
You mention here:
https://youtu.be/jUtzoO-ur34?t=37m23s
That you hate terminal blocks, specifically with stranded wire. I partly agree with you on your rantings. There are great types of terminal blocks that are great for applications such as the CNC machine (less bending/vibration tension, compared to solder joints), especially if you need to pull wires through somewhere and you don't expect the builder to have crimping tools for connectors. Such blocks would be the type that pull the metal block up on the screw, or quick-insertion/easy-release blocks without screws.
But since nobody else seems to use those any more (because $0,02 difference) I can only tell you, get these for the lab, it'll make you much happier in the long run using other people's designs (or cheaper alternatives, but Knipex is the bomb):
http://uk.farnell.com/knipex/97-53-14/crimp-tool-for-cable-ferrules/dp/4135520
http://uk.farnell.com/multicomp/e1508-red/ferrule-16awg-14mm-nylon-red/dp/9972307
http://uk.farnell.com/multicomp/e0508-white/ferrule-22awg-14mm-nylon-white/dp/9972218
http://uk.farnell.com/multicomp/e2518-grey/ferrule-14awg-24mm-nylon-grey/dp/9972650
http://uk.farnell.com/multicomp/e1008-l-red/ferrule-18awg-14-5mm-nylon-red/dp/9972226
http://uk.farnell.com/multicomp/e7508-l-white/ferrule-20awg-14-5mm-nylon-white/dp/9972285
(I posted Farnell links, but the stuff is available everywhere, really. Though the multicomp ferrules for their price hold up better than I expected)
They're actually mandatory in some areas of installation tech over here, since soldered connections or single core wires are very unreliable in vibrating connections (such as CNC machines might be
and generators and such certainly are)
Logged
If it's a puzzle, I want to solve it.
If it's a problem, I need to solve it.
If it's an equation... mjeh, I've got Matlab
(not really though, Matlab annoys me).
Monkeh
Super Contributor
Country:
Re: X-Carve Live Build 4 -> Re Terminal Blocks vs Stranded wire
Reply #1 on:
August 04, 2015, 01:13:45 pm »
Ferrules are the correct solution to stranded wire in most screw terminals, indeed.
Cage clamp (screwless) terminals also work well, and rising clamp is quite suited to larger fine stranded wires.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
EEVblog
EEVblog Specific
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
