Tou and the bank..... The drop ceiling is a standard office feature, put in to hide services like the upper floor water piping and sewage lines, the cabling for the fire detectors and the AC ducting for air handling. In units designated as light industrial or light commercial a dropped ceiling will probably be absent, with a higher roof height ( typically 4m or more as opposed to 3m for office space) with all services exposed on the roof and the lighting surface mounted. There if you have an office area you typically will make it out of either demountable panels, drywall or shutterply ( the cheap option) with a suspended ceiling on top, with the top open and with the cabling, ducting and such lying on top of it.
If you want a more substantial indoor office area you make it from concrete blocks or bricks, though this is then considered a permanent structure inside the unit and if you leave you cannot take it with you, while the demountable can be removed to the new premises.
Where I work we have a mix of demountable partitioning ( came with the building mostly, and got moved around a bit as circumstances changed usage), drywall ( the system we got is obsolete, so we used drywall as cheaper than getting the matching replacement system which is eye wateringly expensive) or for some areas we built brick and block walls for more strength. Just busy patching some areas, where our trainee cleaner put the floor polisher through a glass panel. The other panel was replaced with shutterply as it will never get a hole in it again from that, plus the sheets of ply were cheaper than the drywall sheet and easier to handle as I could get them cut to size by the mill.
