More proof that Batteroo significantly extends battery life.... ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
I have to say, Batteroo, after learning and getting tips from this blog, have finally done a video demo test that covers off some of the very basic requirements. For instance they're comparing like for like, they show the brand new cells being taken out of the pack, they show the equipment and the timer, and it's in one take, and results are shown in a clear chart. Props to them for that. Pity they're still using that awful oleaginous-voiced woman to do the narration. And they stopped the test when the non-batteroo'd torch was still going, and still probably had hours of dim glow left in it.
And yes, as expected (and not denied by anyone), their product works as a boost converter (albeit one which can't maintain a steady fixed output voltage), and they've chosen the one-in-a-million device where using the Batteroo is maybe valid: A dumb, old-fashioned incandescent torch with no built-in boost conversion which runs on a pair of Alkaline D cells. Basically a switch and a bulb in a can.
Trouble is, the world has moved on. No one I know still uses crappy old incan torches anymore (even my parents who are in their 70's and aren't "techie" at all). Nowadays, everyone uses LED torches with fantasic buck/boost converters built in, multiple modes, far more efficiency and brightness, and much more robust than the old incan torches like they used to use in the WWI/WWII era.
Again; of course Batteroo works in this ultra-limited case scenario, but it's solving a problem which simply doesn't exist in 2017.
But again, props to them for doing a much better video test demo than they previously seemed capable of.
