Author Topic: EEVblog #751 - How To Debunk A Product (The Batteriser)  (Read 3140433 times)
0 Members and 48 Guests are viewing this topic.
Offline 5ky
Re: EEVblog #751 - How To Debunk A Product (The Batteriser)
« Reply #925 on: August 26, 2015, 02:46:56 am »
I'm REAAAAAAAAAAAAAAAAALLY curious what the short circuit current of the batteriser will be, and am also curious what its behavior will be when it hits the current limit.  :popcorn:
Offline HighVoltage
« Reply #926 on: August 26, 2015, 06:51:19 am »
Now THAT is strange...just went to watch Dave's Maker Faire interviews video and the entire 46 minute Batteriser video came up as the ad!
That is interesting.
I am blocking all advertisement with "adblock pro"
Offline AmmoJammo
« Reply #927 on: August 26, 2015, 06:55:54 am »
Thats probably where they got their 1.5 amp rating from  :-+
Offline HighVoltage
« Reply #928 on: August 26, 2015, 07:07:11 am »
Yesterday their INDIEGOGO page said 16 hours left.
Now it is another 30 days.
It seems they want to postpone their need to act and hope this "talk" will go away.
Offline AmmoJammo
« Reply #929 on: August 26, 2015, 07:16:23 am »
What You May Request Indiegogo Edit After Your Campaign is Live
As a one-off, Indiegogo allows any campaigner to extend their campaign's deadline to bring their total days live to 60 days (Please note: we are unable to shorten or pull-forward a campaign's deadline).
    Please contact support@indiegogo.com to submit your request for an extension and include the new date upon which you'd like your campaign to end.
    Support must receive request at least 3 business days prior to campaign's current deadline.
Trying to scam as much money as they can maybe?
I mean, if its a functional, saleable device, they won't need the campaign to make more sales...
Offline EEVblogTopic starter
« Reply #930 on: August 26, 2015, 07:21:44 am »
They clearly didn't get the money they were after. If they think they are going to get double after another 30 days, good luck with that, campaigns don't usually work like that.
I think it's the opposite actually. The longer the campaign stays active the more likely people are still going to comment on it.
Offline firewalker
  • Country: gr
« Reply #931 on: August 26, 2015, 07:24:13 am »
Clearly their campaign failed. I was expected the to be well above 500k. So they are seeking a "relance".
Alexander.
Offline pickle9000
« Reply #932 on: August 26, 2015, 07:27:10 am »
I'm thinking outside investor issues.
Offline Galenbo
« Reply #933 on: August 26, 2015, 07:33:00 am »
The boost-converter's efficiency is about 80% - 90%, which can be compensated by the fact that the boost converter can drain battery a bit more than the camera can.
What's the efficiency of 2 boost converters (1 inside, 2nd is batteroo) AFTER eachother? Let's not fall into the trap of just multiplying the % numbers.
And, more important, what's the consumption of those 2 boost converters when the device is OFF? It's not zero, because one of them isn't aware of being OFF.
« Last Edit: August 26, 2015, 07:43:22 am by Galenbo »
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline McBryce
« Reply #934 on: August 26, 2015, 07:43:07 am »
That is very surprising! Someone is paying big money for that, google do not put those there for free, they are payed and targeted ads. Perhaps even targeting my Batteriser videos directly (In Google Adwords you can target specific video or channels and associated keyworks)
I've seen the Batteriser Adsense ads for the website, but not the "fan" videos before.
Don't you get a cut of the advertising shown before your videos? So you are now profitting from the Batteriser?? You've become part of the scam!!  :scared:  ;D
McBryce.
Offline PeterL
« Reply #935 on: August 26, 2015, 08:10:53 am »
Apparently you can extent your campaign by sending IGG a request at least 3 days before the end of a campaign:
https://support.indiegogo.com/hc/en-us/articles/205154117-What-You-Can-Can-t-Edit-After-Your-Campaign-Is-Live
Which seems just like a smart thing to do for them, since the money is still pouring in.
Bob's last (6th) update is now a little strange though stating: "There's only 24 hours left". Again something that doesn't add up well.
« Reply #936 on: August 26, 2015, 10:06:39 am »
Yes, I'll buy a muffin tomorrow with the profits.
Online Fungus
« Reply #937 on: August 26, 2015, 10:21:15 am »
So why did they set an initial target of $30,000?  :-//
Offline AmmoJammo
« Reply #938 on: August 26, 2015, 10:27:35 am »
buy a batteriser ;)
Offline McBryce
« Reply #939 on: August 26, 2015, 10:37:29 am »
That may be more than they ever profit from it! :D
McBryce.
« Reply #940 on: August 26, 2015, 10:54:27 am »
So they can advertise to their VC's and others that it was a massive success being "1000% over funded".
It's a common technique when you don't actually need the money and you are doing it for other reasons.
Offline edy
    • DevHackMod Channel
« Reply #941 on: August 26, 2015, 10:59:53 am »
The low target is probably so it makes it look like they are so popular they are over-funded right away, also convincing potential crowd-funders that it is a sure thing since they are way over target... they will fund the campaign. But they also had a "flexible funding" on the $30k which means they could have raised only $10k and still able to keep the money. It is just for show.
They extended it another 30 days. This story only gets weirder. Their funding curve over the 30 days probably looks just like a battery voltage depletion curve, only flipped in its Y-axis.... Starts off fast, plateaus and then a final quick jump to the finish line.
However, in this case there is a Batteriser attached, so maybe they think it can extend their campaign another 8x! :-)
Offline CaptCrash
« Reply #942 on: August 26, 2015, 11:06:27 am »
Don't you mean 80,000% over funded? It is batteriser after all, don't let math get in the way
Offline Delta
« Reply #943 on: August 26, 2015, 11:36:20 am »
I can see this ending with a "Due to misinformation maliciously spread by interested parties elsewhere online, our major external investors have decided to pull out of the project.  Unfortunately, this means we are unable to deliver the product."  Oh, and we spent all your crowdfunding money on stupid videos, fast cars, and fast women, so no refunds!
Offline McBryce
« Reply #944 on: August 26, 2015, 11:38:42 am »
Well at least they didn't waste it then.
McBryce.
Offline Delta
« Reply #945 on: August 26, 2015, 11:44:19 am »
McBryce.
© G. Best 😃
Offline Jay_Diddy_B
« Reply #946 on: August 26, 2015, 11:45:32 am »
Is there a place where you can get a chart of dollars raised versus time?
Jay_Diddy_B
Online Fungus
« Reply #947 on: August 26, 2015, 11:58:26 am »
No, no, no... the joke is "spent it on loose cars and fast women"
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #948 on: August 26, 2015, 12:11:25 pm »
I just checked and it is confirmed that they have extended for another 30 days, so that then means they can study this and other threads for a month longer, and it looks and sounds like they need to.
I would love to have a serious game of poker with this mob because the card up my sleeve would be the knowledge that they are probably bluffing or even worse a pack of c#£@ts.
Online Fungus
« Reply #949 on: August 26, 2015, 12:25:56 pm »
...but even a drooling idiot can see that $30,000 is way too low, that there's something wrong there.
« Last Edit: August 26, 2015, 12:28:12 pm by Fungus »
