Author Topic: EEVblog #751 - How To Debunk A Product (The Batteriser)  (Read 3140830 times)
0 Members and 45 Guests are viewing this topic.
Offline Fungus
Re: EEVblog #751 - How To Debunk A Product (The Batteriser)
« Reply #5575 on: June 24, 2016, 11:36:08 am »
Maybe they have finished the electronics or perhaps they are still working on it, who knows.
(raises hand)
Me! I know!!
Offline McBryce
« Reply #5576 on: June 24, 2016, 11:44:51 am »
(raises hand)
Me! I know!!
 :D I bet you were one of those kids who sat at the front of the classroom! :D
McBryce.
Offline Macbeth
« Reply #5577 on: June 25, 2016, 09:27:22 pm »
Maybe they have finished the electronics or perhaps they are still working on it, who knows. What interests me is how the hell you pick and place battery sleeves onto pasted up PCBs and expect them to stay upright when going through the reflow oven. Also the sleeve would have to remain dimensionally accurate to match the PCB footprint whilst being reflowed. Even if the product worked it would be an engineering nightmare to manufacture, I suspect it would take a lot of fixures and tooling just to get the manufacturing right. Yet another oversight from Batteroo.
Surely the sleeves would just be spot welded in a jig? Much like regular battery packs with nickel terminal tabs?
...though now you mention it, I wouldn't put it past batteroo to try and pick and place and reflow oven them. Just to give them another excuse as to why manufacturing is delayed..
Offline LabSpokane
« Reply #5578 on: June 26, 2016, 03:27:04 am »
Does anyone know if spot welding stainless to a copper trace is even possible?  I thought that they would *have* to solder the clip to the PCB.
Offline janekm
« Reply #5579 on: June 26, 2016, 04:46:50 am »
It is possible (I've done it before) but the result is not very strong (unless great care is taken in adding lots of vias to the copper to strengthen it).
But the Batterizer is really the very opposite of a hard to manufacture product. The steps are:
- bog-standard PCBM & PCBA
- bog-standard metal die punching and forming (and some type of dip coating)
- solder / weld sleeve component to PCB
- Profit? (this step it seems is where they're having some trouble...)
Yes it'll need a jig for soldering the sleeve to the PCB, but that's trivial for any competent factory / contract manufacturer. We're hardly talking something as complicated as building an injection mold set here (and nobody's too surprised to see a consumer electronics product in a molded plastic case...)
For reliability, it'd make sense to use some type of selective soldering equipment to avoid the reliability issues with manual soldering:
The following users thanked this post: chris_leyson
Offline janekm
« Reply #5580 on: June 26, 2016, 04:52:53 am »
Or if regular selective soldering isn't fun enough, there's always laser selective soldering:
So you'd use a solder paste dispenser (rather than screen printing, as that doesn't work after the regular components are already placed) followed by selective soldering of the sleeve held by a jig.
The following users thanked this post: SNGLinks, chris_leyson
Offline LabSpokane
« Reply #5581 on: June 26, 2016, 05:11:43 am »
OK, well at least I'm not the only one that drops a lot of vias into pads that get battery clips, etc. soldered onto them.
That's the funny thing about the Batteriser.  The failure mode won't just be limited to the lousy electrical engineering - it's likely going to be the peeling of the copper pads since they're in tension when the battery is installed.
Offline Galenbo
« Reply #5582 on: June 26, 2016, 02:56:49 pm »
Thank goodness for screenshots!
Your screenshots can always be redefined as fake images, as part of a conspiracy. And then be used against you, as evidence.
It'd never come to that. Even though images are removed, Facebook retains logs and metadata. Circumstantial evidence alone would suggest that the comments did exist (at least in some form) and were removed by Batteroo themselves. Removal in itself would cast severe doubt on their story and claims that the screenshots were malicious. That's also how a criminal court works, if you can cast doubt or attack someones character over one small aspect, you assume that everything else that person has said was doubtful (even if it wasn't).
You are very unaware of how framing, redefining and oppression works in my part of the world, I'm also happyly surprised of how court works in your part of the world.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline Galenbo
« Reply #5583 on: June 26, 2016, 03:00:17 pm »
The one example I saw, was a combination of a rivet-like deformation and spotwelding.
The deformation for the real-mechanic strength, and the spotwelding for the better electrical contact and to prevent corrosion, they said.
Offline chris_leyson
  • Country: wales
« Reply #5584 on: June 28, 2016, 01:25:28 pm »
Thanks janekm, I really liked the micro soldering video and that's the first time I've seen laser soldering.
Offline Brumby
« Reply #5585 on: June 28, 2016, 01:29:19 pm »
Speaking of firsts, we're still waiting on Batteroo.
Offline rich
« Reply #5586 on: June 28, 2016, 05:04:32 pm »
Well as of yesterday (27 June) the Batteriser+Batterise trademark application/opposition was laid to rest:
By the Trademark Trial and Appeal Board:
On May 20, 2016, Applicant filed an abandonment of its applications Serial Nos. 86571275 and 86571464. On May 23, 2016, Opposer filed a motion seeking judgment under Trademark Rule 2.135.
Trademark Rule 2.135 provides that if, in an inter partes proceeding, the applicant files an abandonment without the written consent of every adverse party to the proceeding, judgment shall be entered against the applicant.
In view thereof, and because Opposer's written consent to the abandonment is not of record, Opposer’s motion is GRANTED. Judgment is hereby entered against Applicant, the opposition is sustained and registration to Applicant is refused.1
Offline meeder
« Reply #5587 on: June 28, 2016, 05:10:31 pm »
So this means that they can use the name batteriser? My legal English isn't that good...
Offline ccs46
« Reply #5588 on: June 28, 2016, 05:13:27 pm »
So their excuse that they can't use the batteriser name is now bullshit.
Edit: Typing on phone. Fixed grammar.
Sent from my iPhone using Tapatalk
« Last Edit: June 28, 2016, 05:17:29 pm by ccs46 »
Normal people... believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet. - Scott Adams
Offline Marcel_X
« Reply #5589 on: June 28, 2016, 05:16:07 pm »
I guess so!
But I guess they'll have additional delays because of this  ;D
"At this point, we already have the Batteriser name and logo design on all of our packaging, cases, wrappers, and brochures as well as the Batteriser product itself. As a result, we will now have to redesign and retool all of these items with our new product name and logo.  We are working on minimizing the effect this change has on our shipping schedule."
They have retooled everything, threw away their original tooling... Back to the drawing board :-DD
Edit: D@mn... Misunderstood the legal stuff. So we'll be hearing about the new name soon I guess!
« Last Edit: June 28, 2016, 05:43:44 pm by Marcel_X »
If it weren't for C, we'd be using BASI, PASAL, and OBOL
Offline rich
« Reply #5590 on: June 28, 2016, 05:18:51 pm »
It means Batteroo abandoned the application for the trademarks 'Batterise' and 'Batteriser'.
And because Energizer didn't agree to abandoning the fight then Energizer win the opposition case by default.
Hope that clarifies things.
The following users thanked this post: samgab
Offline ez24
  • L.D.A.
« Reply #5591 on: June 28, 2016, 05:55:19 pm »
With all this talk of trademarks and tooling, etc.  One would think people think this is a legit project.  I think with so many people believing in this, someone should start a company selling shares in the Brooklyn Bridge.  At least you can see the bridge.
Offline McBryce
« Reply #5592 on: June 28, 2016, 07:22:57 pm »
Put in plain english:
On the 20th of May Batteroo abandoned their application to trademark the names. This was accepted by the trademark body, as the opposer (Energizer) didn't even bother answering the abandonment notice. :)
McBryce.
Offline rich
« Reply #5593 on: June 28, 2016, 07:39:56 pm »
Sorry, McBryce, not quite.
Energizer specifically responded to the abandonment and asked the appeal board to make a ruling. Energizer argued the ruling should go against Batterroo as Energizer did not support the abandonment.
The ruling did go against Batteroo.
somewhere higher up in this thread I posted the juicy parts of those filings.
Offline McBryce
« Reply #5594 on: June 28, 2016, 07:46:53 pm »
Ah, ok. From the single post above I interpreted it slightly different. But the outcome is the same. Batteroo lost.
McBryce.
Offline onlooker
« Reply #5595 on: June 28, 2016, 08:36:26 pm »
The is how one can actually win (the game) by losing (the legal battle).
« Last Edit: June 28, 2016, 08:40:34 pm by onlooker »
Offline ChunkyPastaSauce
« Reply #5596 on: June 28, 2016, 08:40:25 pm »
Backer wrote they sent the following out in an email: "We will be announcing the new product name, unveiling our new logo and supplying further details in the coming weeks."  -  May 7
Offline EEVblogTopic starter
« Reply #5597 on: June 28, 2016, 10:23:51 pm »
They can't even release a name let alone a product   :-DD
I'm still waiting for my media kit. Happy to cover up the Batteroo logo in the video...
Offline Fungus
« Reply #5598 on: June 29, 2016, 05:04:36 am »
It means Batteroo lost. Energizer won.
They can't call it Batteriser.
(And I bet they're not unhappy)
Offline Kjelt
« Reply #5599 on: June 29, 2016, 06:58:12 am »
Terrible name to start with. If you make a product that extends the battery life you should call it so people know what it does and means.
So "batterybooster" or the sorts would have been a more appropriate name.
