Author Topic: EEVblog #751 - How To Debunk A Product (The Batteriser)  (Read 3140433 times)
0 Members and 47 Guests are viewing this topic.
Offline AmmoJammo
Re: EEVblog #751 - How To Debunk A Product (The Batteriser)
« Reply #5100 on: April 07, 2016, 11:48:08 am »
Is there a product to debunk?
Yes
No
Offline amspire
« Reply #5101 on: April 07, 2016, 01:17:09 pm »
One thing that concerns me is Bob's patent application: (apologies if this has been raised already)
http://www.freshpatents.com/-dt20150219ptan20150048785.php
Tucked away in it are these paragraphs:
In another embodiment, a voltage regulation circuit is incorporated within a battery-powered device. The voltage regulation circuit is configured to extend the life of one or more batteries used to power the battery-powered device by outputting a voltage that is equal to or exceeds a minimum voltage required to operate the battery-powered device normally even when the one or more batteries output a voltage that is less than the minimum voltage required to operate the battery-powered device normally.
and
In another aspect, a method is provided for extending the life of a battery. The method includes receiving a battery electrical power output from the battery. The battery electrical power output has a battery output voltage that decreases from a battery first output voltage to a battery second output voltage. The battery electrical power output is used to drive a converter that outputs a converter electrical power having a converter output voltage greater than the battery second output voltage. The converter electrical power is output from one or more output terminals configured to interface with one or more input terminals of a battery powered device.
Isn't this saying that if you have any battery powered device and it has a switching regulator that boosts the voltage to a constant level, then Bob can claim the idea is his invention?
I know the idea is absurd, but once you have a patent, you can scare many companies into paying royalties. Is this the real goal - appear to have an invention of a battery sleeve to boost batteries, but in the process, get a patent that states you invented the whole concept of a switching boost circuit running off a battery in a device?
Offline McBryce
« Reply #5102 on: April 07, 2016, 01:38:09 pm »
I think the fact that this method has been used for years by practically the entire industry would make enforcement of that patent pretty much impossible.
McBryce.
Offline rich
« Reply #5103 on: April 07, 2016, 02:05:05 pm »
and
I thought the patent was supposedly all about the converter packaging (the batteriser), not about when it is inserted (incorporated?) into a battery powered device (probes the monkey). A key phrase:
Offline amspire
« Reply #5104 on: April 07, 2016, 02:14:47 pm »
It includes the Batteriser concept, but it is not limited to that. It includes many embodiments including the concept of a voltage regulating circuit that boosts the battery voltage in a battery powered device.
« Last Edit: April 07, 2016, 02:20:22 pm by amspire »
Offline Nerull
« Reply #5105 on: April 07, 2016, 04:11:31 pm »
To infringe on a patient, you must infringe on all claims. If they have patented a battery sleeve with an integrated boost converter, than the only way to infringe on that patient is to make a battery sleeve with integrated boost converter. Any other boost converter is not a infringement.
This is why companies like Microsoft and Apple tend to get many many very specific patients, rather than a single big patient covering an entire device. For example, when Apple sued Samsung over patient infringement, they didn't claim they violated patients on a iPhone. They had patients such as Design Patent 504,889, for which the claims consist of a single sentence, describing a rectangular electronic device with rounded corners. Because the patient made no other claims, any rectangular device with rounded corners infringed on that patient.
Offline adprom
« Reply #5106 on: April 07, 2016, 05:42:19 pm »
I just noticed this:
Is batteroo planning a 2nd marketing campaign using a different angle?
Offline jippie
« Reply #5107 on: April 07, 2016, 06:12:03 pm »
<youtube video>
Who in his/her right mind would use a flash light to photograph Lady Liberty or the sun? I bet not using flash light for making outside pictures like that saves another landfill of batteries.
Offline LabSpokane
« Reply #5108 on: April 07, 2016, 08:14:24 pm »
Oh FFS, they ditched the monkey for a batter-ROO.  :palm:
Offline ccs46
« Reply #5109 on: April 07, 2016, 09:28:28 pm »
the more information we got the more certain it got.
*The more "Update in a few weeks" that turned into month we got. The more certain it got.   :-DD
Normal people... believe that if it ain't broke, don't fix it. Engineers believe that if it ain't broke, it doesn't have enough features yet. - Scott Adams
Offline AmmoJammo
« Reply #5110 on: April 07, 2016, 10:19:00 pm »
A picture tells a thousand words.
Bob is telling nothing.
Offline WN1X
« Reply #5111 on: April 07, 2016, 10:49:29 pm »
and his spelling is bad  :-DD
- Jim
Offline quad
« Reply #5112 on: April 07, 2016, 11:42:43 pm »
NEW UPDATE!
Offline EEVblogTopic starter
« Reply #5113 on: April 07, 2016, 11:47:36 pm »
 :o
Wow, only took them 6 months or so to show real photos
Very interesting that they are going with the Batteriser name on the sleeve still, obviously they are not concerned about the Trademark dispute with Energizer
Offline lincoln
« Reply #5114 on: April 07, 2016, 11:48:19 pm »
Holy shit, They do exist!! If don't get mine I am going to be so bummed.
Offline Mr.B
« Reply #5115 on: April 08, 2016, 12:05:35 am »
Double holy shit...   :o
Offline rx8pilot
« Reply #5116 on: April 08, 2016, 12:13:11 am »
Now....it is one thing to make a sleeve and another thing to make a sleeve that does what they claim it will do.
« Reply #5117 on: April 08, 2016, 12:17:44 am »
The laws of engineering prevent it from doing the magic it claims to do.
I have no doubt at all it will work as boost converter, the only thing remains is to see how well.
Batteroo know very well once they ship a single unit the game is up, people will flog the arse out of this thing and get data that proves beyond all doubt how poorly it will perform in most applications.
Offline rrinker
« Reply #5118 on: April 08, 2016, 12:20:06 am »
 But note, he says the team is going to China soon - I thought Bob already was in China, per his own post?
Offline g.lewarne
« Reply #5119 on: April 08, 2016, 01:05:36 am »
Now, the question is *how many* are they manufacturing.  All of them? enough for the indegogo supports? only enough for the website orders?
Offline Brumby
« Reply #5120 on: April 08, 2016, 02:02:55 am »
Am I missing something?  Here's what I see...
 - A small panel of 20 circular PCBs (my guess is an original prototyping panel)
 - A single panel of 64 (8 x 8 ) of what looks like finished product
 - One row of what looks like finished product in a jig
To me, this doesn't look like a manufacturing setup.  More like a prototyping and (maybe) process development setup.  I would have been more impressed with something that looked like an assembly line - or at least half a dozen panels.  This does not mean I say they won't ship a product, but I still have reservations.
The one thing these photos DO offer is a chance for all the Batteriser faithful to stand up and use them to beat all the skeptics around the head.  They have been in a vacuum for so long, I expect they will be flag waving like there's no tomorrow.
Offline Stupid Beard
« Reply #5121 on: April 08, 2016, 02:12:58 am »
Had a look at this thread to see what hilarity had ensued since last time I looked. Did not expect actual photos.
Besides renders, is that also the first time they've shown one that's not AA sized?
Offline LabSpokane
« Reply #5122 on: April 08, 2016, 03:29:54 am »
NEW UPDATE!
Holy manufacturability clusterfucks!  The AAs are a train wreck
« Reply #5123 on: April 08, 2016, 04:06:48 am »
NEW UPDATE!
Actually, look at the those two photos. On the large board I do not see any V groove marks on the panel to snap off the rows. But the other photo shows a row of AA's in some sort of assembly/test jig holder.
What's up with that?  :-//
Offline Mr.B
« Reply #5124 on: April 08, 2016, 04:13:21 am »
Smoke and mirrors maybe...
