Have you guys seen the batteriser video where they demo the batteriser in an apple bluetooth keyboard? It's ridiculous and REALLY misleading to the average joe.
They put in "dead" batteries that show 13% capacity left in OS X on the laptop it's paired to, then they pop those same batteries into batterisers, then back into the keyboard, then the OS power monitor for the keyboard shows the keyboard is at 100%. They were VERY careful with their wording in that video. Not once did they ever say the word energy or capacity. They only said "these dead batteries show 13%" and "it now shows 100%". That will mislead the general public to believe that it means it's actually full capacity, but obviously the capacity monitor uses battery voltage to give you a capacity percent. When you boost the voltage back up to the voltage of fresh cells, the capacity monitor will think the batteries are at full capacity, which is not even remotely true in that case. For all we know, those batteries actually have only 15 minutes of juice left in them but due to their misleading video, people will assume it'll go as long as fresh batteries would last when you use the batteriser on empty cells. Grrrrrrrrrrrrr those fools are driving me insane. Link to said video:
Their website FAQ section had a question about current capability and their answer was "No, the Batteriser sleeve is designed to deliver as much current as a battery is able to supply to the device."
![Bullshit Detector :bullshit:](https://www.eevblog.com/forum/Smileys/default/BullshitDetector.gif)
So.... I'm supposed to believe that their boost converter using an inductor half the size of a grain of rice is capable of 5-10 amps like a fresh AA battery can put out? Baloney. There's a reason why they never used batteriser in that stupid monkey, and why their "demo" videos are always in really low current devices like remotes, bluetooth keyboards, low power 3.5mm led flashlights, etc.
I made a video about this a couple weeks ago because I was so pissed when I saw that video. Their other videos are pretty dubious also, but that's no surprise. I'm VERY excited for my campaign rewards.
