Nah, probably Lenina Huxley from Demolition Man. The main protagonist also does teardowns, blows stuff up and can be regularly seen with a large knife. Makes sense.
Perfect sense. Probably it gives also a preview of the next project. Nowadays codenamed as: Project G.I.R.L.
ETA: Presentation in EEVblog #1000 (Come on, that´s doable!)
BTW: Typical engineer.
Started a project. Had thereby fun with fiddling and tweaking (perhaps with the tongue in the right angle).
But the biggest part of the real work of construction was delegated to an other.
After arriving of the complete done order, if it´s a success, then presenting the result as the proud initiator.
It´s always the same...
In every case:
From Germany 12 Points!
Congratulations to Mr. and Mrs. Jones!
Best wishes to Sagan and his new pal Huxley!
