This is a copy of a reply I posted on the fluke 117 review.
I have the 117 and like the non contact feature because I work with high voltage.
I also have a fluke 16 which is a continuation of the fluke 12. It measures temperature and uA as well as caps. I had the fluke 12 for 10 years which only cost me 100 in 1994. I fell in love with this meter immediately. It had low Z was small, rugged and had 4 push buttons. I found the low z great for many things including discharging capacitors and testing batteries and power supplies.
These low end meters had a little known feature which Dave would love. The fluke 16 still has it although i did not find it in the manual. I believe you use the range button when in diode mode. It has a latch open and a latch close to check a cable for shorts or breaks. If you hold the leads together and hit a button it will detect a momentary open, but has a display which shows up as —__ on the display. otherwise the display looks like —–. Like a logic transition. Correct me if wrong, but this is a feature not included in higher models, I believe.
Love the blog Dave keep it up. Electronics has been my passion for over 20 years.
Reuben
While I am on the topic of meters I love, I have an Ideal amp meter with a tight sight display. There is a little rubber boot over a second display in the end. This is great for high hanging wires. This meter has min max capacitance, frequency through the jaws and an analog bar graph. It also has a great back light and huge digits. Sorry fluke, but I like this better than yours especially at under 200.
It looks and feels “sexy” as Dave would say. I had it checked by a calibration lab and they said it was “spot on”.
More on ideal amp meter. I have had it for 4 years. I really like the canvas belt holster and it comes with wonderful probes which come apart to put a huge black alligator clamp on the black lead for one handed testing. It is also cat III and IV. Check it out
I have been using ideal’s vibrating low impedance meter (wiggy} for about 6 years and you want to talk rugged? I dropped mine from 50 feet. It has a solenoid which vibrates and a analog meter with ever famous neon lamps. Strangely, works well to test unloaded frequency drives.
