I'm happy for you, K. Give us your review as you have time. It looks in very good shape, practically new.
You're old DMM seems to be quite well used, a testament also to its durability.
Note, for safety the lightning annunciator to warn you about the shock potential of the V you have on.
Thanks Mate for your positive spirit
I will write few words about my feelings, for the Newcomer ..
The first quirk found on it , was at the temperature setting, the inner sensor in order to work ,
needs from your end , to have leads crossed ( in contact ) ... thats stupid ... but understandable .
It does not have an separate K-Prob input , so it needs my help to react properly.
With out the leads crossed the screen reads {
OPEn } ( circuit )
The holster , with the extended rear ( foot - leg - support point ) , does not look to be well designed ,
it causes the feeling that the instrument will fall - flip , by an accidental sock , or even by pooling the test leads in your direction.
( I am working on a solution about it , I had not made my mind yet )
Check this picture..
Another quirk that I found , are the clear plastic on the display ,
its so shiny that causes reflections " glare " , even with the indoor lighting.
( An not shinny LCD protector film , could be the answer )
Another quirkAt High Resolution mode ... at 20V (end of the high resolution road )
The meter correctly show as {
19.999 } above that drops to {
20.10 },that is logical.
In order to show again the high Resolution , it does not need to lower the voltage to less than 20 again , but to drop it down to 16.80 ... then it shows again High resolution . Why ? .. why why ? tight asses
( My DC PSU has an 30 turns potentiometer on it ... I have to do 3-4 complete rotations to drop it that low !! )
Other than that , the instrument looks solid ... Thanks God
Few posts above I had speak about the inner Fuses, quick acting ones.
And I just feel the need to explain my view - opinion - conclusion .
a) About the Fuse ratings , the higher Fuse ratting , will force the manufacturer ,
to make one equal rated PCB design and electronics .... So the MetraWatt must be better made than Fluke, so to survive in such an incident .
b) Fuse rating - Max breaking capacity in KA or thousands of Ampere ....
We need some one more expert , to tell us whats going on here ..
By combining scattered info .. like ..
1) The 87 Fluke can do 20A at 20 secs at 1KV
2) Fluke recently updated the fuse rating from 17KA to 20KA ( 20.000A) ( 11A one)
3) The word capacity = Amperes + time = keep alive seconds
By combining all those , the MetraWatt should doing if I am not mistaken ,
as 20A for 30 seconds Max !!
So its 33.3% more powerful in this area .
c) We should not " force " the people , to throw away good tools , just from fear ,
that could " possibly " blow - explode .... I recommencement to all who haves such instruments ,
to get an pair of " fusible probes " ... simple - effective - cheap.
d) Common glass fuses , does not explode , never did .
The car industry uses those for years .
Still , by replacing your old fuses , with " quick active ones " ( those with grey body instead of glass ),
its an clever or smart thing to do , those modern - better - fuses , are probably used on the fusible probes too.
e) One last notice about multimeter 's with slots and openings on the front panel.
Those are totally " in door " designs ... moisture or liquids are the enemy here .
One little opening on the multimeter , its not possible to be an enemy.
But for out door usage ... there are high risks , but this haves to worry mostly the industrial electricians,
that they " have to " work in all weather conditions, & also use "open type toolboxes" ,
or if the environment that they work , are full of steams - heat or what ever other factor ,
that could raise the humidity level sky high , and could transform one simple multimeter ,
in to a wet stick ...
Yes there is special gloves - boots - cloths ,
but electricity uses always the most direct path to meet you .
About my old and brave one
I had never removed the protective cheap nylon from the face plate ,
but even so , looks and works great .
Dave.. I started reading your theory about the " burden voltage " .
Interesting stuff - for advanced tasks. ( but lets stay on topic)
