Author Topic: Livecam fails ???  (Read 9238 times)
Offline ProBang2Topic starter
Livecam fails ???
« on: April 15, 2015, 12:05:51 am »
Hello.
The live livecam doesn´t work ...  :-//
(look at the picture)
Or... - is there something top secret going on in the lab???  ???
Greetings
Hartmut
Re: Livecam fails ???
« Reply #1 on: April 16, 2015, 04:33:24 am »
Hello.
... and the mystery continues ...   ???
(screenshot below)
I´m the only one with problems?    :'(
Greetings,
Hartmut
Offline German_EE
« Reply #2 on: April 16, 2015, 09:29:43 pm »
I'm the only one with problems?
No, I have not seen a working live camera at the EEV Blog for months.
Warren Buffett
« Reply #3 on: April 16, 2015, 11:17:58 pm »
Hello.
Strange... The labcam via DropCam worked very well.
Since the change to ConnectCast three weeks ago it failed.
Update:
Since 15 Minutes (01.00 MEZ) I´m receiving a live-pic on the EEVblog-page.  :clap: :clap: :clap:
Perhaps you can get the livestream direct from http://connectcast.tv/eevblog
Greetings,
Hartmut
Offline EEVblog
« Reply #4 on: April 17, 2015, 12:20:27 am »
There are issues with it but it generally works.
It is not on 24/7 like the old one, 8am to 8pm Sydney time only. It gets powered down outside those times.
Offline ozwolf
« Reply #5 on: April 17, 2015, 05:11:54 am »
Any thoughts on fixing the stop action?  It's a little annoying, and makes it difficult for me to lipread what you're saying to Dave2.
I reject your reality and substitute my own.
« Reply #6 on: April 24, 2015, 01:57:22 am »
Hello.
I know. There is in every screenshot a window, showing the time in Sydney.
But, what´s now going on???
"Only partners are allowed to use embed feature."   :wtf:
BTW: The stream on http://connectcast.tv/eevblog still works...
« Last Edit: April 24, 2015, 02:03:37 am by ProBang2 »
Offline EEVblog
« Reply #7 on: April 24, 2015, 05:26:13 am »
That's new...
Offline Fennec
« Reply #8 on: April 28, 2015, 09:06:57 am »
Same here, this cam does not working. (Firefox / OpenSuse 13.2  64bit)
Offline EEVblog
« Reply #9 on: April 28, 2015, 09:22:07 am »
Connectcast have said they are updating things and it's screwing up everything. They are working on it...
Offline Fennec
« Reply #10 on: April 28, 2015, 07:57:20 pm »
It never worked on my Linux system but did on windows. But, the same could be said for Dropcam.
Then it must something wrong with your system. Dropcam has worked everytime on OpenSuse 64 bit.  Its shockwave-flash
With the new one, go with your mouse in the left down corner (popup), there are other Cams listed. ALL of them are working here, but not Daves.
Windows I don't have, can't check.
« Last Edit: April 28, 2015, 08:02:34 pm by Fennec »
Offline Fennec
« Reply #11 on: April 28, 2015, 10:49:03 pm »
currios..
Offline lapm
« Reply #12 on: May 11, 2015, 10:07:46 am »
Personally i have failed to see even one stream from new cam. They do allow streaming outside Australia?
All i ever see is this: Only partners are allowed to use embed feature. Click here to learn more about our partnership program.
Thanks to doing regular rotation of night-evening-morning at work its easy trying to catch lab spy cam ;)
Electronics, Linux, Programming, Science... im interested all of it...
« Reply #13 on: May 20, 2015, 01:30:19 am »
Hello.
Look yourself. Hmmmm... - where is the failure in this picture?
« Reply #14 on: May 20, 2015, 04:29:17 am »
Three hours later...
It is now 2:28 pm in Sydney. Still the same on the website.            :=\
The livecam is offline. Perhaps someone has unplugged the timer?   :-//
Offline EEVblog
« Reply #15 on: May 20, 2015, 12:42:10 pm »
There might still be an issues with the power supply used. Reports are powering a webcam through the USB port on the Rpi is not a good idea, it needs an external powered hub.
Offline EEVblog
« Reply #16 on: May 20, 2015, 01:11:07 pm »
Why do you have the camera on a timer? Is it to save power, or bandwidth?
Bandwidth.
If the later then maybe you could stop and start the camera feed only via some scheduled start/stop commands on the RPi.
Why bother when you can save power too and also have it cold reboot daily to ensure reliability?
Offline lapm
« Reply #17 on: May 26, 2015, 10:36:18 am »
Bandwidth.
Then best thing would be properly shut (with shutdown command) it down to minimize risk of garbage ending up in memory card. Since raspi keeps some files open in there while running..
