Author Topic: My DIY Solder smoke and fume hood  (Read 5055 times)
Offline jmctechTopic starter
« on: April 06, 2015, 12:32:10 am »
Redoing my work area and needed a solution for smoke and fume, It is in the basement and the wife gets upset especially if I let the magic smoke out of something as the work area is directly below the master bedroom. A friend of mine owns a heating and cooling company and made me the hood in about 10 minutes. Used a four inch 100 cfm duct fan as the extractor. It is going to vent outside. I have glass block windows and can remove one block and install a dryer vent on the outside.
Re: My DIY Solder smoke and fume hood
« Reply #1 on: April 06, 2015, 12:51:39 am »
Admin if you can move this to the correct spot, I posted from Tapatalk and for some reason it went here, I have tried to delete it but it wouldnt let me. Thanks, Jason
Offline Fungus
« Reply #2 on: April 13, 2015, 12:55:29 pm »
Is breathing solder smoke bad for you?
« Reply #3 on: April 13, 2015, 04:18:35 pm »
About the same as smoking Texan plain. Just without the nicotine hit, the rest of the cyclic aromatics, nano size particulates and organic acids are all there.
http://www.cigarettespedia.com/index.php/Texan_%28Toasted_Plain%29_S-20-S_-_South_Africa
Lovely things those, 21 per pack, 20 rolled and one loose leaf. The best coffin nails you could buy cheap.
Offline Tallie
« Reply #4 on: April 14, 2015, 12:29:32 am »
Yes... I filter mine through a cigarette.
Offline Psi
« Reply #5 on: April 14, 2015, 12:58:05 am »
Better than trying to extract the fumes with ya noise i guess.
