Author Topic: EEVblog #720 - Mailbag  (Read 26680 times)
Offline EEVblogTopic starter
Offline hamdi.tn
  • Country: tn
Re: EEVblog #720 - Mailbag
« Reply #1 on: March 03, 2015, 11:38:20 am »
the dude who for whatever reason flipped the oscilloscope up side down  :o hi  ;) why  ??? and am not sure what he think about his employer holding that knife , i will be scared  :-DD
Offline kayvee
« Reply #2 on: March 03, 2015, 11:49:26 am »
He has to ease into the limelight slowly, you know....  ;D
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: March 03, 2015, 12:02:13 pm »
The Old Scope Inverse Manoeuvre.     :-+ :-- :-DD
It's obviously so that you can trigger on either a rising or falling edge
without wearing out the buttons on the scope, just brilliant Seppy.
Muttley
« Last Edit: March 03, 2015, 01:28:26 pm by Muttley Snickers »
Offline max666
  • Country: at
« Reply #4 on: March 03, 2015, 12:25:49 pm »
I like the postcards. Maybe I'm biased
Offline bundy
« Reply #5 on: March 03, 2015, 01:13:48 pm »
That strange routing on the Supermicro Xeon board is called offset routing. It is to minimize the influence of the FR4 glass fibers on the controlled impedance. The Er is slightly different at the point of the woven fiber bundle than in between them.
The large unpopulated area on the board is for a SAS interface, Serial Attached SCSI.
Offline PinheadBE
  • Pinball Freak
« Reply #6 on: March 03, 2015, 01:45:38 pm »
The datasheet is from the big metal shielded part on the Automated Voltage Regulator.    Not the whole module, but only the part (or hybrid module ?) that is under the metal casing (which apparently doubles as heatsink for some power switching devices).
This would explain that there are, indeed, SMT parts under there.....
BTW, Dave: you've got one of your scopes stored headside down...
Please, don't drink and blog....  :palm:
A bit more, and you would pretend that *someone* just flipped your scope just to annoy you....
Come on ...... |O
Please keep our planet clean
Offline jancumps
  • New Low
« Reply #7 on: March 03, 2015, 02:10:15 pm »
Can you believe that I didn't see the apprentice.
I watched again after reading all the scope comments here - and yes, now I get it.
I must have been hypnotized by the knife.
Offline dexters_lab
« Reply #8 on: March 03, 2015, 02:18:30 pm »
 :-+ Love the nonchalant attitude while your new helper makes an appearance.
when does he get introduced?
Offline daqq
  • Country: sk
    • My site
« Reply #9 on: March 03, 2015, 02:51:31 pm »
Hi Dave,
When you are dealing with 1TB of RAM you might consider creating a RAM drive for some serious speed boost - you don't need 1 TB of RAM for your application software (not sure if windows is even capable of it) most of the time.
Offline FHR
  • Country: cz
  • I love Linux
    • FHRNet.eu
« Reply #10 on: March 03, 2015, 03:39:01 pm »
Hey dave,
You need at least 2 DDR3 DIMM RAM sticks, one for each CPU.
Also beware that older servers may have DDR2 memory, which is not compatible. You cant also mix ECC and NON-ECC RAM.
Offline elgonzo
« Reply #11 on: March 03, 2015, 03:46:51 pm »
Totally awesome and funny appearance of Seppy.
Watch older Mailbags (EEVblog #680 and older) and look for that particular oscilloscope...  ;)
(I have to admit, until i saw Seppy's joke i did not realize that Dave did not have that upside-down scope in the most recent mailbags anymore)
« Last Edit: March 03, 2015, 03:50:52 pm by elgonzo »
Offline NRoach44
« Reply #12 on: March 03, 2015, 03:48:57 pm »
The unpopulated pads at ~5:30 is for a SAS (Serial Attached SCSI) controller (big BGA pad, and the shape of the connector silkscreen give it away. And the labelling for the connectors being "SAS0~3")
Offline pb2k
« Reply #13 on: March 03, 2015, 03:52:12 pm »
Hey dave,
The memory is quad channel, so populate all of the blue slots on the board, if you can with with identical speed and sized modules.
Also be aware that according to the quick specs on the supermicro site EEC and non-ECC are supported, but not registered (or Fully buffered, not that FB ddr3 dimms exits)
Look for memory codes like PC3-10600E.
Offline elgonzo
« Reply #14 on: March 03, 2015, 04:04:55 pm »
:o?  Of course it supports registered ECC DDR3 DIMMs...
Offline FHR
  • Country: cz
  • I love Linux
    • FHRNet.eu
« Reply #15 on: March 03, 2015, 04:13:31 pm »
Of course It supports registered RAM. It will also run in single channel mode, no need to buy 8 sticks.
Offline pb2k
« Reply #16 on: March 03, 2015, 04:16:06 pm »
My bad.
From the full blown manual:
"The X9DA7/X9DAE motherboard supports up to 1 TB of Load Reduced (LRDIMM),
512 GB of Registered (RDIMM) or 128 GB of Unbuffered (UDIMM) ECC/Non-ECC
DDR3 800/1066/1333/1600/1866 MHz 240-pin 4-channel memory modules in 16
DIMM slots."
Offline Grapsus
« Reply #17 on: March 03, 2015, 04:56:42 pm »
It's a good thing that this motherboard supports both kinds of DIMM (registered and regular).
Which kind of RAM to buy will depend on the desired total amount of RAM.
If it's less than 128 GB, then stuffing this puppy with unregistered non-ecc 8 GB sticks will be the absolute cheapest.
If more than 128 GB are required there is no choice but to buy buffered RAM which will be like two times more expensive and will maybe add a bit of access latency.
In any case, I'd advise to stay away from ECC UDIMM and NON-ECC RDIMM which are uncommon and expensive.
With LRDIMM it's possible to get 1 TB of RAM, but it probably costs more than a kidney.
And please don't listen to stupid advice about ECC RAM on youtube. For a 32 GB machine, the real life data about RAM errors is like one over a year of continuous operation. For storage servers with certain filesystems, it's absolutely required, but for a single video rendering machine it would be a waste of money.
« Last Edit: March 03, 2015, 04:59:08 pm by Grapsus »
Offline dentaku
« Reply #18 on: March 03, 2015, 06:16:11 pm »
It's great to see stuff manufactured in Nova Scotia like the Chip Whisperer.
Of course Colin lives near Dartmouth which seems to be the only place to get electronic related parts and tools in NS. I know you can order anything online these days but it's still nice to have a real store to check new stuff out sometimes.
« Last Edit: March 03, 2015, 06:17:42 pm by dentaku »
Offline Switching Power
  • professional hobbyist and design engineer
« Reply #19 on: March 03, 2015, 06:37:08 pm »
This would also make a nice postcard ;)
http://dilbert.com/strip/1999-03-02
Offline Neilm
« Reply #20 on: March 03, 2015, 07:23:04 pm »
Had to laugh at the appearance of Daves new PFY
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline max666
  • Country: at
« Reply #21 on: March 03, 2015, 07:46:21 pm »
Offline RupertGo
« Reply #22 on: March 04, 2015, 12:39:48 am »
Loved the ChipTorturer... er, Whisperer. Bet you can lose a few hours to that baby.
I only mention this because it's normally so good, but there's a spot of hum on the audio from time to time - you can hear it most clearly at around 6:40. Sounds more like inductive hum rather than dodgy shielding, from the way the level changes between cuts. Nothing terrible and no interest in being a precious snowflake on this, but if a bit of cable repositioning can restore the pristine crispness of Dave's unique tonality, then why the hell not.
And props to the Dave Soundboard chap for not doing what I'dve done, and stringing together some of the standard phrases or sayings into proper rudeness, as a bad man could so easily do...
Offline miguelvp
« Reply #23 on: March 04, 2015, 01:55:18 am »
Don't forget to put heatsinks to those Xeons, like this one that came from a DELL Precision 490
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #24 on: March 04, 2015, 03:23:55 am »
It was done for our Northern Hemisphere viewers - who had previously been uncomfortable with the Aussie-centric nature of Dave's presentations.
Date will still be dd/mm/yy  or yymmdd - but NEVER mm/dd/yy - EVER!
Don't ask a question if you aren't willing to listen to the answer.
