0 Members and 17 Guests are viewing this topic.
Just opened my UT61B bought for 58€ in a brick and mortar shop (40 less than the next cheapest: the Brymen i really wanted including postage) last northern hemisphere summer.I seems to have the input protection and proper fusing. It's quite ok and well built for the price.And if the 61B(GS) 200107-7 code mean that the PCB was designed then? If that's the case, they've been able to do so since at least 2001!
Quote from: gildasd on February 09, 2015, 10:55:27 amIt's quite ok and well built for the price.And if the 61B(GS) 200107-7 code mean that the PCB was designed then? If that's the case, they've been able to do so since at least 2001!The problem is that the management of that company feel it's OK to lie to customers and rip them off.There's alternatives out there. Uni-T don't really deserve anybody's business until there's nothing but well built meters in their lineup and they've recalled all the bad ones from stores.OK, they're not going to do that but they should at the very least remove the CAT-IV labels and market them for what they are.Plus HRC fuses and proper track clearances aren't that expensive to do. That's pretty much all it would take to bump the safety up by an order of magnitude.
Does it say that anywhere other than buried deep within the Users Guide? I could forgive someone for thinking that a U1232A would have a decent mA range contained within the A range just as it has mV ranges contained within it's V range.
Quote from: gildasd on February 09, 2015, 10:55:27 amJust opened my UT61B bought for 58€ in a brick and mortar shop (40 less than the next cheapest: the Brymen i really wanted including postage) last northern hemisphere summer.I seems to have the input protection and proper fusing. It's quite ok and well built for the price.And if the 61B(GS) 200107-7 code mean that the PCB was designed then? If that's the case, they've been able to do so since at least 2001!It looks like you have a GS version modified with the old original BS1362 fuses in place and all MOVs removed. Not good.
Quote from: TMM on February 09, 2015, 11:06:04 amDoes it say that anywhere other than buried deep within the Users Guide? I could forgive someone for thinking that a U1232A would have a decent mA range contained within the A range just as it has mV ranges contained within it's V range.I thought it was pretty obvious from the front panel. It doesn't say mA/uA or mA/A like most meters do.
Right now, my only alternative are the yellow hard plastic 5€ jobbies from the hardware store... I don't want those, even for free.Your video only reinforced that belief
This is really interseting: I have the UT61E which you are showing towards the end of the video. Mine is only rated 300V CAT III and not 600V CAT IV.Despite that mine has a better input protection: A bigger HRC fuse for the 10 amps (690V, I1=80kA), 4 MOVs, and 3 PTCs.Here are the photos of my UT61E:https://dl.dropboxusercontent.com/u/11083462/DSCN1240.JPGhttps://dl.dropboxusercontent.com/u/11083462/DSCN1241.JPG
Safer, yes. A lot of features are lacking: No AC+DC, 1kHz AC bandwidth only, 0.1% accuracy instead of 0.025%, no internal memory, optional PC connection, no peak hold and no current input jack aural warning.Still, a pretty good meter.
Quote from: Wytnucls on February 09, 2015, 01:21:53 pmSafer, yes. A lot of features are lacking: No AC+DC, 1kHz AC bandwidth only, 0.1% accuracy instead of 0.025%, no internal memory, optional PC connection, no peak hold and no current input jack aural warning.Still, a pretty good meter.not really: it has true-rms, pc connection, and warnings if your probes are not in the right connectors...if you want 0.025%, take the vc880 for 30E more (but no W measure)I don't say it's the best dmm but It's OK for lots of usages.Which dmm would you buy for less than 200E if you had to choose one ?
Quote from: Maister on February 09, 2015, 09:23:35 amI have the UT61E which you are showing towards the end of the video. Mine is only rated 300V CAT III and not 600V CAT IV.Despite that mine has a better input protection: A bigger HRC fuse for the 10 amps (690V, I1=80kA), 4 MOVs, and 3 PTCs.Where did you buy it?
Quote from: Wytnucls on February 09, 2015, 11:22:44 amQuote from: gildasd on February 09, 2015, 10:55:27 amJust opened my UT61B bought for 58€ in a brick and mortar shop (40 less than the next cheapest: the Brymen i really wanted including postage) last northern hemisphere summer.I seems to have the input protection and proper fusing. It's quite ok and well built for the price.And if the 61B(GS) 200107-7 code mean that the PCB was designed then? If that's the case, they've been able to do so since at least 2001!It looks like you have a GS version modified with the old original BS1362 fuses in place and all MOVs removed. Not good.That opens up a few questions:- Can I solder some on?- What should be they be rated at?- Should someone start a thread on "How to make your UT61 less crap for a couple of Euros" (by someone competent, I'm not).
4) Lying about a rating is just dangerous and wrong and a lawsuit is waiting to happen.
In the EU, as far as I know, it's the First importer / seller of a CE marked product who carries the responsability for the CE marking. Now how you prove who's first? But it may be something to think of if you import and sell, as manufacturers in China seem to slap on CE marks on everything.
Quote from: Tepe on February 09, 2015, 11:07:49 amWhere did you buy it?My girlfriend bought it from www.reichelt.de (Germany) (X-Mas present for me )
I would agree that this is a bad meter, here is why I think so;1) The design engineer planned to put better components on the board, but Management told them to cut the cost and they had to compromise of safety and on accuracy. What other compromises are hiding in this meter??2) A meter in this price class should have precision resistors and not pots that can drift over time and start to corrode.3) I bet you that the drift of this meter is terrible, with time & temp & moisture this meter will go out of spec really quick.4) Lying about a rating is just dangerous and wrong and a lawsuit is waiting to happen.
Quote from: Wytnucls on February 09, 2015, 01:21:53 pmSafer, yes. A lot of features are lacking: No AC+DC, 1kHz AC bandwidth only, 0.1% accuracy instead of 0.025%, no internal memory, optional PC connection, no peak hold and no current input jack aural warning.Still, a pretty good meter.not really: it has true-rms, pc connection, and warnings if your probes are not in the right connectors...if you want 0.025% and true rms ac+dc, take the vc880 for 30E more (but no W measure)I don't say it's the best dmm but It's OK for lots of usages.Which dmm would you buy for less than 200E if you had to choose one ?
