Author Topic: EEVblog #689 - Back To The Future Time Circuits Troubleshooting  (Read 14208 times)
Online EEVblogTopic starter
« on: December 03, 2014, 10:03:10 pm »
Dave troubleshoots the Back To The Future Time Circuits in 'real-time", warts and all.
A journey of red herrings, garden paths, the bleeding obvious, and the inevitability of Murphy's Law.
Can you discover the fault before Dave does?
Discussion and comparison of the Tagarno microscope vs the Mantis 3D stereo microscope.
TLC59282 Datasheet: http://www.ti.com/lit/ds/symlink/tlc59282.pdf
The live camera feed: http://www.eevblog.com/live
« Last Edit: December 03, 2014, 10:16:48 pm by EEVblog »
Offline Towger
  • Country: ie
Re: EEVblog #689 - Back To The Future Time Circuits Troubleshooting
« Reply #1 on: December 03, 2014, 10:16:53 pm »
The curse of the EEVblog defeated...
Offline nitro2k01
« Reply #2 on: December 04, 2014, 01:05:49 am »
Here's a simple idea to improve the contrast on the yellow display: Put some Kapton tape over it if you have a suitable width roll.
Offline EvilGeniusSkis
« Reply #3 on: December 04, 2014, 06:56:14 am »
Dave good to see you fix the time circuits, Doc Brown would be proud!!! I really liked this http://youtu.be/4-PhbPS5LQU?t=34m9s view for the soldering and would like to see it used more.
Offline bktemp
« Reply #4 on: December 04, 2014, 07:02:21 am »
I have reworked many PCBs with soldering errors, brokes traces and other common faults. One thing I have learned quickly was: When probing signals, you can use vias, SMD pads or other easily reachable points as an initial test. But always check each signal right at the end, directly at the point where it goes into the plastic of the ic. This is the only way to be sure the signals reach their destination.
At 13:00 when Dave probes the COLO signal, the frequency counter in the upper right corner of the scope shows about 5kHz, but the frequency counter at the bottom shows 122Hz. Can anybody explain what causes this difference?
Offline JackOfVA
« Reply #5 on: December 04, 2014, 02:26:25 pm »
In ye olde days when DIP TTL or RTL chips were installed in sockets, it was certainly not unknown for the pin-to-socket connection to fail or, more often, be intermittent.
Offline eV1Te
  • Your trusted friend in science!
    • richardandersson.net
« Reply #6 on: December 04, 2014, 04:24:16 pm »
The top one is a hardware counter, while the bottom one only calculate the frequency in software from the data in the display buffer.
Offline Supercharged
« Reply #7 on: December 04, 2014, 06:09:10 pm »
This footprint error is nothing against something i did  :palm: i had to acctualy bend the pins
Science is about what is, engeneering is about what can be.
-Neil Armstrong
Offline vlad777
« Reply #8 on: December 04, 2014, 06:14:22 pm »
This video is amazing.
When you touched the chip and contents changed , THAT was the main clue.
(Dave thought it was capacitive signal integrity problem but it was cold solder.)
Yet everyone would have missed it.
Mind over matter. Pain over mind. Boss over pain.
Offline Tek_TDS220
« Reply #9 on: December 04, 2014, 06:32:06 pm »
Nice work, Dave.  I've learned that when I hand solder IC SMT parts, that I need to do a continuity check on each pin.  It's a pain, but it saves headaches later.
You did a careful job of soldering and used plenty of flux, but still had a problem with poor wetting between the pad and the pin.  Poor joints are very difficult to see, even with the excellent microscopes that you have.
Offline rs20
« Reply #10 on: December 05, 2014, 09:22:49 am »
Yikes, one chip multiplexed over 8 displays, no resistors to spare the TLC chip the full brunt of the LED's excess voltage drop; no wonder this thing is either hot or dim...
Offline marcan
  • If it ain't broke I'll fix it anyway.
    • My blog
« Reply #11 on: December 05, 2014, 10:25:15 am »
Heh, when Dave touched the chip with his finger I immediately though that it must be an issue with a control input being floating - clock or some kind of clock gate or latch.
What bugs me though is that he thought that the other two boards were fine to begin with. They're three identical boards and they were all connected together when the connector SNAFU happened; identical chips tend to blow identically, and just because the magic smoke didn't escape doesn't mean the silicon wasn't thoroughly cooked. After reworking the first board, I would've completely disconnected the other two boards and worked on the first one alone until it worked - that ensures that neither are the other boards negatively affecting the first, nor that you might be accidentally mislead by assuming anything about their state.
Admittedly though, the IC failure mode happening to have almost the same symptoms as the bad soldering was one heck of a confusing coincidence.
Offline rs20
« Reply #12 on: December 05, 2014, 11:22:36 am »
I wonder if the chip that failed most spectacularly actually shunted the damaging voltage away and "protected" the other chips from failing quite as spectacularly (even though they still got damaged beyond repair)?
What bugs me though is that he thought that the other two boards were fine to begin with. They're three identical boards and they were all connected together when the connector SNAFU happened; identical chips tend to blow identically, ...
But these chips didn't blow identically. The one chip he initially replaced failed short, which is a very obvious fault. It's the fact that the others also failed, but in a more subtle way, that understandably led him astray.
Offline marcan
    • My blog
« Reply #13 on: December 05, 2014, 02:16:17 pm »
What I meant is that identical chips tend to blow under the same conditions; they were exposed to the same (grossly outside absolute max ratings) environment. I wouldn't trust any chip that was exposed to something like that, particularly not when at least one unit has failed. That doesn't mean they're guaranteed dead, of course, but at least I'd isolate them until they can be independently tested.
I do like your theory of one chip failing short and preventing the others from blowing up too though.
« Last Edit: December 05, 2014, 02:26:29 pm by marcan »
Offline hans12
« Reply #14 on: December 05, 2014, 06:08:16 pm »
I used to have an old HP laserprinter which printed everything about 1% smaller. I found out after I had etched a board with a DIP40 socket on it, it did not fit anymore.
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #15 on: December 05, 2014, 07:26:28 pm »
Be careful when you print; this is often a setting in the driver or the program doing the printing.  For example, PDFs always seem to like to "fit to page" which means they get shrunk, most often.
Online Monkeh
« Reply #16 on: December 05, 2014, 07:31:06 pm »
Software in general likes that as a default because it avoids clueless users not grasping why things don't fit on the page.
Offline hans12
« Reply #17 on: December 05, 2014, 09:28:40 pm »
It did that too if you scaled to i.e. 80%. The thing just always printed 1% smaller. Ended up patching the software to render 1% bigger and that solved it.
Offline Fungus
« Reply #18 on: December 05, 2014, 09:39:11 pm »
You mean the TLC Constant Current LED Driver...?
Offline snipersquad100
    • Electrinics
« Reply #19 on: December 05, 2014, 10:27:02 pm »
how do you download the eagle files from github. when I click on it a just get a page of code.
Offline grumpydoc
« Reply #20 on: December 05, 2014, 10:35:03 pm »
To provide some counter-examples
When I was, oh 15 or 16, I repaired a transistor radio for the brother of someone I knew.
He (the owner of the radio) had decided to save himself the cost of fresh batteries by running the radio from the mains but didn't quite grasp the difference between the two sources of power and connected 240V AC straight to the 9V battery terminals.
Amazingly the only thing which was fried was the audio amp output transistors which had clearly melted quickly enough to protect the rest of the radio.
A bit later when I was doing more repairs someone brought in a guitar amp - the sort of thing with a few inputs connected via a basic mixer feeding a power amplifier all basically mounted in a 'speaker enclosure. The story was that a disgruntled band member with an axe to grind with the owner of the amp had wired a BS 1363 to 1/4" jack lead - plugged one end into the mains and the other into the amp and turned the power on.
The inputs were fed into op amps - TL071 or similar - the one which bore the full brunt of 240V AC was literally blown apart, the next mixer channel along had the op amp shorted across the power rails but physically looked OK. Every other passive and active device survived intact.
Sometimes things survive extreme abuse better that you'd guess they would.
« Last Edit: December 06, 2014, 11:38:19 am by grumpydoc »
Offline thm_w
  • Non-expert
« Reply #21 on: December 05, 2014, 11:32:58 pm »
Right click on Raw on that page, top right, and save link as.
Since its XML there is some browser confusion on how to handle the file. Also GIT probably thinks you will use their gui/command line tool to sync files.
Offline nitro2k01
« Reply #22 on: December 06, 2014, 03:04:11 am »
Though arguably, he should maybe have understood that when one chip died with a magic smoke vent from having the polarity of the power supply reversed, the rest of the chips of the same kind couldn't have fared well either. On the other hand the purpose of the video was of course not simply fixing the sign, but doing some show and tell troubleshooting. From that angle it was a good video.
And also, this is a good example of when a pin header could have been made fail safe when reversed but wasn't. Especially since multiple pins are used for ground and led V+ respectively. As many pins as possible could have been matched to connect to the same pin when connected either way, and the remaining two pins (since the number of pins for each rail is odd in this case) could have been connected to an IO where this wouldn't have caused damage.
« Last Edit: December 06, 2014, 07:22:18 am by nitro2k01 »
Offline rs20
« Reply #23 on: December 06, 2014, 06:39:52 am »
Yes. Now I'm not sure if you're just clarifying what I mean, or trying to hint that I don't understand what constant current means; but in case it's the latter: Let's just assume the LED drops 2V @ 20mA (probably nowhere near right but not the point). The way this circuit was implemented:
2V drop + 3V drop across TLC chip = 5V supply. 3V drop across TLC chip * 20 mA = 60mW dissipation per line.
My proposal:
2V drop + 2V drop across fixed 100ohm resistors + 1V drop across TLC chip = 5V supply. Yada yada, 20mW dissipation per line. Much cooler running. The same thermal load is now spread between the TLC chip and the 16 resistors.
And also, this is a good example of when a pin header could have been made fail safe when reversed when wasn't. Especially since multiple pins are used for ground and led V+ respectively. As many pins as possible could have been matched to connect to the same pin when connected either way, and the remaining two pins (since the number of pins for each rail is odd in this case) could have been connected to an IO where this wouldn't have caused damage.
Agreed. Or use real polarised sockets in the PCB!
« Last Edit: December 06, 2014, 06:47:18 am by rs20 »
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
« Reply #24 on: December 06, 2014, 09:08:49 pm »
I use Git GUI. It took me some time to figure out just what to do before I found this program. Google is your friend. Search Git GUI. Or, try this: http://git-scm.com/downloads Then use the Clone existing repository, Enter the url and do the rest. It'll save the WHOLE repository in a folder of your choice & location.
Some help: http://code.tutsplus.com/tutorials/git-on-windows-for-newbs--net-25847
« Last Edit: December 06, 2014, 09:33:33 pm by Quarlo Klobrigney »
Voltage does not flow, nor does voltage go.
