Author Topic: EEVblog #670 - FLIR TG165 Lepton Sensor Followup  (Read 24199 times)
Offline EEVblogTopic starter
« on: October 04, 2014, 10:03:29 am »
A followup on the FLIR TG165 Visual Thermometer / Thermal Camera teardown. A look at the micro-shutter and some thermal chamber experiments and scope measurements on the SPI data from the Lepton sensor used.
Offline woox2k
  • Country: ee
Re: EEVblog #670 - FLIR TG165 Lepton Sensor Followup
« Reply #1 on: October 04, 2014, 10:42:01 am »
Power the sensor without any external controller, then you know for sure what is controlling the shutter.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: October 04, 2014, 11:09:58 am »
Lepton datasheet : https://drive.google.com/file/d/0B3wmCw6bdPqFdXI1bEFnOHdWZTQ/edit
I2C bus isn't used for much at the moment it seems. Flir haven't yet released the command spec.
There is some info in the examples on the Pure Engineering page
http://www.pureengineering.com/projects/lepton
But I couldn't get the Flir One sensor to respond to most of them, so I guess firmware is different.
Day Job: Mostly LEDs
Offline rs20
« Reply #3 on: October 04, 2014, 11:12:52 am »
The fact that it seems to be working with no I2C interaction could be a very nice bit of design -- when the Lepton sensor wakes up, it just starts outputting video straight away, and takes care of NUC itself. If you want more control (e.g. "Dear Lepton sensor, I've just placed a shutter that I know is at 24.37 degrees C in your field of view, calibrate off that please"), you're free to take control via I2C, but many simpler applications like this won't need to go to that complication. I'll take five!
Offline nitro2k01
« Reply #4 on: October 04, 2014, 11:36:42 am »
With the risk of making a fool of myself, (or possibly you!) are you sure that you were actually probing the I2C clock pin? It seems odd that there would be a single ~500 ns pulse on the I2C bus. It would make sense if there was no activity, but a single pulse? Maybe there's a hardware bug, and the module won't start up without that pulse...
« Reply #5 on: October 04, 2014, 11:37:32 am »
Yes, I thought that was very elegant, no mess, no fuss.
« Reply #6 on: October 04, 2014, 11:38:46 am »
Pretty sure, I buzzed it out.
Likely just a setup thing on the micro or something.
« Reply #7 on: October 04, 2014, 11:54:49 am »
Wouldn't surprise me if Flir products using their Lepton had unique firmware for each product, and it's only the OEM modules they sell would be as documented.
« Last Edit: October 04, 2014, 12:21:10 pm by EEVblog »
Offline nowlan
« Reply #8 on: October 04, 2014, 12:16:28 pm »
You mean flir?
btw: i heared fresnel is pronounced fren-nell.
« Reply #9 on: October 04, 2014, 12:22:31 pm »
 I've never heard anyone in Australia pronounce it like that.
« Reply #10 on: October 04, 2014, 12:36:37 pm »
I also embarassed myself saying vig-netting instead of vinyetting.
Why be embarrassed, countless people say it either way, just like many other thing, and it's perfectly acceptable. The anal retentives can choke on it  >:D
« Reply #11 on: October 04, 2014, 12:58:01 pm »
As it's French the "s" is technically silent, but most people seem to pronounce it these days
Offline David_AVD
« Reply #12 on: October 04, 2014, 09:13:31 pm »
In the stage lighting industry everyone says it as "fren-ell", but most people new to the term usually say "frez-nell".  I know I did years ago.
Offline marshallh
    • retroactive
« Reply #13 on: October 04, 2014, 10:57:45 pm »
Yes it's "freh-nell"
Verilog tips
BGA soldering intro
Offline nitro2k01
« Reply #14 on: October 05, 2014, 02:52:37 am »
@6:41  "There you go it just blinked!"
So must I have, because I missed it.
From Dave's tone of voice, I suspect he edited the video to remove some dead time, and happened to edit a way a bit too much.
Offline morpheus
« Reply #15 on: October 05, 2014, 07:34:03 am »
Is it possible to buy one of thoosse lepton sensors somewhere, without buying whole thing?
Offline Stonent
« Reply #16 on: October 05, 2014, 07:43:09 am »
I think mike's videos on the Flir one he said they weren't available to buy.
« Reply #17 on: October 05, 2014, 08:24:48 am »
Sure, if you want to buy 1000qty at $250ea they will be happy to take your money. All others get a  :--
« Reply #18 on: October 05, 2014, 08:51:53 am »
And of course for that price they will only enable the features you order, and disable the rest permanently. They will also lock in the resolution and frame rate you want as well, and will not allow you to disclose any info under a NDA.
« Reply #19 on: October 05, 2014, 09:21:04 am »
Resolution & framerate are fixed, though I suspect it is capable of higher framerate  - why else would the interface run at 3x the actual rate...
Datasheet is released (link above) & I'm told the I2C command stuff is on its way
Offline morpheus
« Reply #20 on: October 05, 2014, 09:36:10 am »
Yeah, not a option for me :( Is there similar modules, with at least 60x60 resolution, available for hobbyists?
Offline Grapsus
« Reply #21 on: October 05, 2014, 09:42:29 am »
Apparently some people obtained a deal from Flir which enables them to order in 100 batches : https://groupgets.com/campaigns/31-flir-lepton-thermal-imager-batch-2
Still, 250 bucks is a stiff price if it's just for playing around with the sensor with no real project.
Maybe I2C is used to update the internal firmware of the sensor ? It might be interesting to trigger a firmware update on the device and probe the I2C bus at the same time...
« Reply #22 on: October 05, 2014, 09:54:28 am »
I'd be surprised if the TG165 had the ability to update the FW on the sensor.
Since Seek Thermal announced, Flir Ones have started dropping below RRP on Ebay, and combined with the Iphone 6 launch, I don't think it will be long before you will be able to easily get an F1 to harvest the sensor for $250 or less. Even if Flir don't drop the F1 price.
Offline Stonent
« Reply #23 on: October 05, 2014, 08:24:39 pm »
Does the F1 sensor pulse the 2 micro-shutter pins when it does a correction or does that come from elsewhere on that sensor?
« Reply #24 on: October 05, 2014, 09:17:18 pm »
Unless it's a product that has the shutter, I doubt it would try to activate it ( it's possible it may sense if the coil is connected), as it needs to know if there is a shutter, otherwise it would try to cal from an image that was not "flat"
