Real TEGs are expensive, $35 to 40 a pop at single piece prices, but they're worth it if you've got expendable income. Charge a cell phone with your camp stove kind of power outputs.
As has been mentioned they're great for when you have an application you can't get to to run power lines, like a old factory retrofit, buried sensors you cant get a field repair tech to replace, geothermal heat and mining applications, spacecraft that have a long term radioactive heat source. Russia used them in remote locations to power radio communication devices in the 50s and 60s.
Mosquito traps use them because they burn fuel to produce the CO2 and heat signature they're attracted to and the nail in the coffin is the electric powered fan they get sucked in with.
They're also commonly used as off grid back ups for wind/solar, just have an ignited fuel source kick in.
for $40 you can buy a lot of spare LiPos. At this point rich kid hikers would be the biggest market.
To check to see if it's a real TEG check the max temp conditions, 300C (400C in bursts), they also have high temp silicone insulation on the leads.
In idea conditions on a good mudule you can get anywhere from 10W, but you'd need conditions like I have, northwestern Minnesota winter. A outdoor stove is a perfect application for these, you could power thermostats/dampers or a fuel feed auger.
It's all about the delta T, eventually your cold side is going to heat up, in less than ideal conditions without a good cold source you're going to see 5W out of that same module if your trying to use ambient temp/heat sinks to cool. Best to find a water source/radiator.
Bismuth Telluride is a byproduct of lead mining, a finite resource unless people start recycling metals for their bismuth, a commonly used alloy.
There are two main manufacturers of real TEGs Marlow Industries and Tellurex. I know Tellurex has an online store based out of the US you can purchase directly
Scroll down to the bottom for their Thermal Power Generators.
Click here for tellurex.com
