What do you know, it only needed the 5V supply to the ADC board. Edit: seems like the half amp my PC can supply is not enough to power both the BeMicro and the BeScope, probably with a powered hub it might work without powering both boards.
Not much I can do with it yet because the software is very limited to adjust to longer time periods but it's a pretty good base to start with.
By the way, it gets pretty warm!
Pictures of the device generating 2.5MHz and 5.0MHz ringing square waves as well what the DS2202 sees.
2.5MHz:
![](https://www.eevblog.com/forum/blog/eevblog-661-mailbag/?action=dlattach;attach=109361;image)
5.0MHz:
![](https://www.eevblog.com/forum/blog/eevblog-661-mailbag/?action=dlattach;attach=109365;image)
Rigol:
![](https://www.eevblog.com/forum/blog/eevblog-661-mailbag/?action=dlattach;attach=109363;image)
![](https://www.eevblog.com/forum/blog/eevblog-661-mailbag/?action=dlattach;attach=109367;image)
The last two attachments are the full res captures, the ones in here where resized to be 800 pixels wide instead of 1324 pixels wide.
Edit: Not bad at all for just $50, the thing I'm more exited about is the SDP Interposer so I can connect to other Analog Devices boards.
http://wiki.analog.com/resources/alliances/alteraAlso the connector Analog Devices uses is a Hirose FX8-120S-SV that mates with the FX8-120P-SV in the Interposer, they are fairly cheap.
Edit: BTW the reference clock comes from an SIT8033AC-31-25A-5.00000 2-Frequency Select Oscillator in this case it's a 5MHz divisible by two with by driving the FS pin. Looks very precise (the clock not the BeScope).
http://www.sitime.com/products/datasheets/sit8033/SiT8033-datasheet.pdfI can't find any in stock but I've seen other frequencies/dividers available.
I wonder if the output can be cleaned up, the output clock is pulled down by a 1K 1/8W 1% resistor.
![](https://www.eevblog.com/forum/blog/eevblog-661-mailbag/?action=dlattach;attach=109381;image)
