In those glorious pre-FCC certification days, all that digital RF leakage could be a feature, rather than a bug. If you put a MW/AM radio next to the computer (not necessarily that close!) and wrote some tight timing loops with memory access in assembler, you could play tunes. Which was something, as there was no other way to get sound out of some of those early micros. (Sometimes you could flip bits on the cassette out port... you could still pick that up on the AM radio, though.)
Advanced users could also use the AM pickup technique to debug software, as with a bit of experience you could hear the distinct tones of subroutines or even put in little blips as checkpoints. There was even an early UK computer - 50s or 60s, I think an Elliot Automation model - that had an audio amp and a probe built into the chassis so you could hear what was going on at various bus points. With low clock speeds, there was a lot you could pick up.
BTW - I've always heard that it was a TRS 80 Model 100, the NEC 4-line LCD AA-powered portable, that had the last code Bill Gates ever wrote in it. It was certainly his pet project, and the 8080 Microsoft BASIC for the Altair was the first thing he and Paul Allen wrote when they started Microsoft. A legendary piece of coding.
But a lovely teardown. I really like those horrible brown ceramic decoupling caps, which remind me of the Hong Kong 5 transistor superhet radios I cut my teeth on as a schoolkid in the 70s. Tiny circuit diagrams pasted in the back of the case, earphone sockets and crappy PP3 battery connectors that failed in microseconds, and that 'fill a shotgun with components and fire it at the PCB' manufacturing technique. Happy days.
