Author Topic: EEVblog #638 - Apollo Saturn V LVDC Testing  (Read 18987 times)
Offline EEVblogTopic starter
« Last Edit: July 07, 2014, 02:12:00 am by EEVblog »
Offline HP-ILnerd
Re: EEVblog #638 - Apollo Saturn V LVDC Testing
« Reply #1 on: July 07, 2014, 03:39:59 am »
Phenomenal.
I love vintage tech, Apollo-era tech in particular.  Those guys were really striking out into unknown territory on every front.
Personally, I can't get enough of this sort of thing.
« Reply #2 on: July 07, 2014, 03:58:28 am »
Did they make a functional programming computer from discrete components? I doubt emulation would have been easy in the 1960's.
Yeah, that would be interesting to know!
You would think they would have had to have something to emulate/test on?
Offline HP-ILnerd
« Reply #3 on: July 07, 2014, 06:13:54 am »
I may go out to visit him late this summer and pick up what I can and help him clean out his techno-junk ( as he calls it). I will share what I can with the EEVBLOG community and then send the rest off to the Smithsonian
Bob
I hope you have a decent camera!
Offline G7PSK
  • It is hot until proved not.
« Reply #4 on: July 07, 2014, 08:40:33 am »
I read that in flight the equipment ran on 28 volts but on the launch pad it ran at 97 volts, and it was running at the high voltage on the pad that caused the insulation on the LOX heater on Apollo 13 to fail and led to the eventual blowing of the tank when it was stirred on the way to the moon.
Offline digital
« Reply #5 on: July 07, 2014, 09:51:09 am »
What a great video it was a treat to see the board and the layout it would be great to be able to talk to the design engineers from that time that were involved in the design of that board and why they did not compact the chips further.When you slid the chip out of the connectors i thought you may have used your heat gun to gently burn of the oxidation but hey you did it.thumbs up Dave.Cheers
Offline max_torque
    • bitdynamics
« Reply #6 on: July 07, 2014, 11:06:31 am »
On a project as complicated and interwoven as the Apollo system, designers of individual systems were typically just given a set of targets and told to get on with it!  Due to the lead times, and constraints of project management** you were given a mass/space/power envelope and a set of performance requirements and from those you designed your system.  With reliability and flexibility high up the list, much higher than capability / integration.
Because of those factors, the designers of all the Apollo systems chose proven, high reliability blocks from which to construct their systems.  With it's roots in the Mercury and Gemini space projects, a lot of the electronic tech was even at the start of the project nearly a decade old, but when someone says "I want man on the moon in under 10 years" you don't start re-inventing the wheel ;-)
The system of very basic ICs on cards is incredibly flexible, and because each "chunk" is relatively simple, testing and production validation during build / assembly is much easier.  The requirement to provide test hardware early in the program life (a long time before anything actually flew) mean't that it was inevitable that changes to the control logic and execution paths would occur, and that a massively modular architecture enables that to occur without significant re-certification for flight (In effect, you make a few very basic components, certify the heck out of them, and then use them in their thousands, rather than using fewer but more complex and each slightly different components!)
There are a good series of videos uploaed to Youtube that cover the status of the Apollo project through the years.  As someone who thought the project was about building a moon rocket, the amount of support systems and infrastructure engineering and development is simply mind blowing.  Compared to some of the test systems, building the actual rocket was relatively easy:
** imagine trying to project manage a project the size of Apollo today, even with all our computerised management systems it would be a massive PITA, in the 1960's with paper and pencil, just managing the work scope/flow must have been a nightmare!)
« Reply #7 on: July 07, 2014, 12:01:40 pm »
Sure but I expected at a bit more integration like a maybe latch chip or something?
Some of these chips only have two resistors in them!
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #8 on: July 07, 2014, 12:25:33 pm »
Great video of this classic 1960 era design.
I do however find it a bit strange that the chips are slid into holders and not soldered in place.
I know the chip was a bit tough to move due to years of build up and oxidation.
We know the rocket produced a lot of vibration and thrust, I guess they were not concerned about the chips sliding out of the holders.
Offline German_EE
« Reply #9 on: July 07, 2014, 12:41:35 pm »
My nomination for the next destination of the board is Mike @ Mike's Electric Stuff, he has an X-Ray machine and should be able to see inside the chips and the board layers.
I was always told that TTL was invented for the Apollo program and it looks like you have proved me wrong as those chips use RTL. It's still an interesting video though and like many others I was surprised by the spring contacts. Weight was a massive problem on the Apollo flights and subcontractors were limited in the amount of solder that they could use on the joints so those clips are a puzzle.
The combination of Health & Safety, MBAs and Death by Powerpoint mean that we probably couldn't build the Saturn V now and I'm not holding my breath for the new launch systems. Sad.
Warren Buffett
« Reply #10 on: July 07, 2014, 12:59:16 pm »
Fran has already done that.
Offline LabSpokane
« Reply #11 on: July 07, 2014, 01:24:40 pm »
Dave,
The US space program is extremely conservative. Even the Columbia shuttle used Apollo era core memory - at least initially. Two resistors on an "IC" isn't too surprising given the era.
Offline RupertGo
« Reply #12 on: July 07, 2014, 02:21:37 pm »
TTL certainly built on the modular approach that Apollo spearheaded, but it was quite different in concept otherwise. http://www.embedded.com/electronics-blogs/break-points/4431173/TTL-turns-50--more-or-less--in-2014- is an interesting piece that points out 2014 is the 50th anniversary of the 5400 series of parts. Perhaps Dave could do a Birthday Special on SSI and MSI logic? I cut my teeth on 74/74LS/40XX TTL and CMOS parts..
« Reply #13 on: July 07, 2014, 04:56:51 pm »
Built in the 1960's, using a frozen tech that was probably started in 1961 and held there.
crDSC01484 by SeanB_ZA, on Flickr
This is an example of late 1960's to early 1970's avionics, simple SSI on a large board designed somewhat for being repairable. Has some serial CCD memory as well, in the 2 Mostek chips on there. Made in the late 1970's, but the design was finalised probably a few years before for testing and certification. Most of the chips are now completely obsolete.
Offline bktemp
« Reply #14 on: July 07, 2014, 05:30:00 pm »
In comparision with the Apollo Guidance Computer, the LVDC looks ancient:
http://en.wikipedia.org/wiki/Apollo_Guidance_Computer
Offline max_torque
    • bitdynamics
« Reply #15 on: July 07, 2014, 07:03:57 pm »
I don't know for sure, but i would suggest that the basic "rocket guidance and control" tasks for apollo had their roots firmly in Mercury and Gemini, as getting up into orbit is broadly the same task for all conventional rocket systems.  That makes the components and sub systems in the LVDC much more likely to have their ancestry in the early 1950's.
However, the guidance computer, required to leave orbit and get to (and back from ;-) the moon, well, that was a very specific Apollo requirement, and as such could be expected to be made up of more up-to-date technology and processes as it must had to have been developed specifically for Apollo.
Offline RobP
Offline PA0PBZ
« Reply #17 on: July 07, 2014, 08:09:39 pm »
It's a 12 layer board:
The resistors are on the bottom of the module:
I have a lot of info about the LVDC, unfortunately the PDF is 84 MB, just a little bit too much to attach  :o
Offline KK
« Reply #18 on: July 07, 2014, 08:10:10 pm »
Phenomenal.
My Uncle ( now close to 90 years old) lives in New Jersey and was the program manager for the LEM ( lunar excursion module) when he worked for Grumman in the 1960's. He still has a letter from LBJ hanging in his living room congratulating him and his team on the successful mission to the moon. He says that he doesn't have much hardware but has some declassified schematics of the cameras used on the LEM. I may go out to visit him late this summer and pick up what I can and help him clean out his techno-junk ( as he calls it). I will share what I can with the EEVBLOG community and then send the rest off to the Smithsonian
Bob
"From the Earth to the Moon" was a great documentary about the Apollo program. They had a specific segment on the LEM and the Grumman engineering team in NJ led by Tom Kelly. There is a scene where he is on the phone with his boss, presumably your Uncle? getting the go ahead for the project. I can't remember that name.
Fine engineering from all involved in that project!
Offline PA0PBZ
« Reply #19 on: July 07, 2014, 08:20:56 pm »
The original drawings of the INV and AA modules. I sent them to Fran, maybe this is what was sent to Dave also:
Examples of the two highest usage blocks are shown in Figures 2-10
and 2-11. Figure 2-10 shows an INV module which contains an inverter with
a permanently connected 1.5k AND and an extra 2.5k AND. Two INV modules
are required to form a latch. The AA module of Figure 2-11 is used to obtain
AND and OR diodes and AND resistors. For example, the AA module may be
used to obtain two three-input 2.5k AND's with two OR diodes, a seven-input
2.5k AND with one OR diode, or just to obtain eight AND diodes. The versatility
of these modules allows just two modules to satisfy all logic connections
with minimum waste of unused components.
« Last Edit: July 07, 2014, 08:32:41 pm by PA0PBZ »
Offline bobwidlar
  • analog IC design engineer
« Reply #20 on: July 07, 2014, 10:25:58 pm »
I can only guess why they didn't integrate further is because they started the project years before the launch. So, IC technology was relatively new and they didn't order IC's for the project. It's already mentioned above, Apollo guidance computer's first version was using ~4k ICs and the most complex one was 3-input NOR gate (3 BJT + 4 resistor). That was it, that was what possible with the first planar bipolar process. In 1964 we can see uA702 and integration boost coming.
BTW: here's a nice talk about Fairchild history, and around 48:00 they talk a little bit about how tough was to meet apollo program specs http://youtu.be/arIXj8xpf6Q?t=47m45s Later on they say that each chip of dual 3-input NOR gate they sell to Apollo program was 9.9$ but for other customers it was 0.99$
« Last Edit: July 07, 2014, 11:36:40 pm by bobwidlar »
Offline warp_foo
« Reply #21 on: July 08, 2014, 01:21:49 am »
Phenomenal.
Bob
Spider. Best episode of the series..
« Last Edit: July 08, 2014, 01:23:36 am by warp_foo »
Offline PA4TIM
« Reply #22 on: July 08, 2014, 06:33:47 am »
I restored a HP9100A and B. They are from the dame eara. That is, one I managed to repair, the other showed some sings of live, (but it was found under a floor, near sea, and showed signs of salt water).  No sevice manuals, a big collection of hand-drawn schematics made by tony, the authority in 9100 land, but very hard to follow and project to actual pcbs. Everything was current driven that made probing not easy. The very rare, short, electrostatic CRT that was broken in the B version. Most common problem with these beasts.
This is a cutting edge calulator, the first programmable sceintific calculator (it even can do complex numbers)
I made a lot of pictures and it is made very interesting. It has hundereds of transistors and diodes. uses core memonrie and, a magnetic card reader. But on the other hand was the first use of teflon as pcb and some boards are multilayer with many layers.
If I understand well the ROM was made by a multilayer pcb which formed a matrix of crossing wires to makle some sort of replacement for core memory.]
If you can lay your hands on one it could be footage for an interesting tear down video. I do not have them anymore. I restored them for a museum.
http://www.pa4tim.nl/?p=3964   The 9100A that was very easy to fix
http://www.pa4tim.nl/?p=3878  The 9100B with lots of detail pictures. I got it to work with a round tube that fitted the cabinet more or less. But it seemed like the rom was gone. The crt showed some activity, it seemed to react to operators but it made no sence, After 2 months I gave up.
The multilayer teflon board :
Some of the > 1000 diodes in this thing
Offline Homer J Simpson
« Reply #23 on: July 08, 2014, 10:01:34 am »
Here is the like to the Wikipedia article on the LVDC with some more details.
http://en.wikipedia.org/wiki/Saturn_Launch_Vehicle_Digital_Computer
Triple redundant logic with a voting system.
2.048 MHz.
Reliability of 99.6% over 250 hours of operation.
and.........water cooling.
Not bad for 50 years ago.
KT
« Reply #24 on: July 08, 2014, 11:30:58 am »
I've had the keyword on ebay watch for some time! No joy  :(
