Author Topic: EEVblog #639 - IBM L40SX Retro Laptop Teardown  (Read 21032 times)
Offline EEVblogTopic starter
Re: EEVblog #639 - IBM L40SX Retro Laptop Teardown
« Reply #25 on: July 12, 2014, 08:08:53 am »
What strikes me about that laptop is how over-complicated it is. A (huge!) external switch mode power supply and tons of linear regulators on a fat heatsink?
One of those on the heatsink is a switchmode controller.
That odd (and doubtless costly) PLL board? All that 74 series logic glue? I know that state-of-the-art early 90s PC design was nowhere near as well-integrated as it was to become, and IBM never had a tradition of cost-reduction (quite the opposite), but I do wonder what the design criteria were.
Probably to reuse as many existing IBM stocked part numbers as possible. Also faster to market that way.
Offline richardkb
« Reply #26 on: July 12, 2014, 07:36:59 pm »
Error code 161 dead battery and 163 date and time not set.
The 2 batteries were for CMOS settings and ram hold up when the system went into sleep/hibernation.
Early Toshiba laptops also had 2 sets of small battery packs.
Rich
« Last Edit: July 12, 2014, 07:46:32 pm by richardkb »
Offline Stonent
« Reply #27 on: July 12, 2014, 11:16:01 pm »
Oh and the 32bit issues on the old 386 processors didn't affect a lot of people initially because everyone was using windows 3.0 and 3.1.  32 bit instructions didn't come into play unless they were running OS/2. Windows 3.1 didn't use 32 bit instructions unless you enabled 32 bit enhanced mode manually which few people did and I don't think used the instructions that had the problems.
I enabled that on a lot of computers over the years and most everyone was like "My computer feels twice as fast!"
Offline SteveSmith
« Reply #28 on: July 15, 2014, 04:08:13 am »
The keyboard on that was sold by IBM as an external unit. They sold a couple of versions of it, some with built in TrackPoints, some without, and I believe ISO and ANSI layouts were available too.
Here's mine:
Much like the laptop, there was an external numeric keypad that you could get for that keyboard, too. Been hunting one of those for a long time now.
*Edit* Forgot to actually list the model number. That was the IBM Model M4-1 Space Saving Keyboard with Trackpoint.
Offline f4eru
    • Chargehanger
« Reply #29 on: July 18, 2014, 06:02:12 pm »
Hi Dave,
Why not ripping out the inside stuff, and put a modern motherboard, battery and screen ? would be ice to use the keyboard
