I remember, 2008 during my vocacional trainig (I was 19) I also was suggested to use an old Simpson brand analog multimeter for repair jobs. It was quite easy to find defective transistors inside an old 6,5V 80A linear power supply (Rack mount 2U). That device contained not less than 15 2N3055 all mounted in parallel with balancing resistors. It was a heavy device with many faults. I replaced about 4 transistors, but could not proceed to test, because that repair shop did not have a dummy load to test this device under maximum load. In the cabinets, we also have some Multavi 5, but they are not used anymore, even if they still work.
The most impressing battery life i've ever seen was inside an old Rode & Schwarz URV. That device was maybe 30 or more years old, but the battery was still nearly full. With growing frequencies and more modern digital power meters, the URV has also become obsolete.
