Author Topic: EEVblog #632 - Solar Roadways Are BULLSHIT!  (Read 417460 times)
Offline james_s
Re: EEVblog #632 - Solar Roadways Are BULLSHIT!
« Reply #1000 on: March 02, 2017, 11:36:40 pm »
I still can't figure out how this idea even got started. I mean of all the places one could put solar panels, why roads? I could it being considered if we had installed so many panels that we ran out of roof space and were running out of exterior walls, already had one on top of every utility pole, the top cap on every fence, wall, railing and every other semi-practical location then ok fine, consider roads. Better yet how about sidewalks? They generally spend less time covered with big things like cars, and a lot less wear & tear. Until that time when we run out of all the vastly more sensible places to put them, roads?! Really?
Offline Brumby
« Reply #1001 on: March 03, 2017, 12:38:47 am »
You're asking the wrong questions.
A better series of questions might be:
 Q. I want to make money in an industry that's underdeveloped where funding can be found... What could that be?
 A. Renewable Energy!
 Q. What technology can I reasonably play with in my garage?
 A. PV Solar!
 Q. Now, where can I put them? ........
« Last Edit: March 03, 2017, 12:40:21 am by Brumby »
Offline james_s
« Reply #1002 on: March 03, 2017, 01:25:56 am »
But the answer to the "Now where can I put them" question, there are so many reasonable and at least semi-reasonable answers that come before "roads."
Offline josecamoessilva
« Reply #1003 on: March 03, 2017, 02:12:22 am »
But the other places were logical (or more logical) so there were other people already working on them. A new product must be distinctive. (Apparently they skipped the part of the class that mentions feasible and economical  :horse:)
Offline Brumby
« Reply #1004 on: March 03, 2017, 03:36:09 am »
You got it!
Offline f4eru
    • Chargehanger
« Reply #1005 on: March 03, 2017, 09:18:12 am »
The reasoning goes more like :
"oh, there's a possibility to extract subventions from the sector of road construction and green energy"
"yeah, le's do that !"
"ok, what can we do ?"
"let's put PV over the road"
"that's expensive, we need a lot of structure to put a roof over roads"
"le'ts put PV directly on the road then, with cars rolling over it"
"but that's ineffective and doesn't last long"
"we don't care, we want only subventions for nice and cheap demo projects"
"OK, let's do it"
Offline Domagoj T
  • Country: hr
« Reply #1006 on: March 03, 2017, 05:40:32 pm »
Iffy roadways don't have to be solar :)
Does it come with a complimentary burger?
Offline EEVblogTopic starter
« Reply #1007 on: March 06, 2017, 10:35:58 am »
Thunderf00t posted this!
New panels been in less than a month and it's failed AGAIN!
Both fully off and high brightness problem?
Online Kean
    • Kean Electronics
« Reply #1008 on: March 06, 2017, 10:51:22 am »
The "high brightness problem" actually seems to be part of the animation.  It moves between panels.
But one is certainly dead - not at all surprising.
Offline madires
  • A qualified hobbyist ;)
« Reply #1009 on: March 06, 2017, 11:05:50 am »
How embarrassing >:D Considering how long it took to produce the new panels their yield must be quite bad. And if tested panels fail so soon the production process seems to be a lottery. Haven't they spent 5 years or so on that?
Offline bktemp
« Reply #1010 on: March 06, 2017, 11:10:55 am »
It is not fully off, there is one LED stuck fully on...
It would be interesting so see if/how they fix those problems: Is it only a crashed microcontroller on the individual tiles, so cycling power fixes the problem, or did the tile really fail?
Some days ago I noticed two darker panels with some snow on them, but they fixed them a couple of hours later.
So my guess was, probably those panels had a bad connector and got less voltage, therefore the LEDs were dimmer and the heater also did not get its full power. But it didn't look like they removed any of the tiles to repair the wiring, so it was either a bad connection inside the kiosk/power supply cabinet or a software problem.
Offline Domagoj T
  • Country: hr
« Reply #1011 on: March 06, 2017, 09:20:08 pm »
Last time, random passersby jumping on panels seemed to do the trick.
Offline LabSpokane
« Reply #1012 on: March 06, 2017, 10:26:41 pm »
 Now that the 2nd install has failed, the webcam has been taken down for "maintenance."
Again.
Offline ataradov
    • Personal site
« Reply #1013 on: March 06, 2017, 10:30:55 pm »
I wonder who owns the camera? If it is owned by the city, then they should be able to comment on this? Do SR guys have control over it? Why? Would be nice to get some comments from the officials.
Alex
Offline LabSpokane
« Reply #1014 on: March 07, 2017, 12:15:51 am »
Owned and operated by the city.
Offline ataradov
    • Personal site
« Reply #1015 on: March 07, 2017, 12:28:04 am »
Then SR can't take down the stream on their own, presumably? I would not think that the city is interested in hiding faults of this technology.
Alex
Offline LabSpokane
« Reply #1016 on: March 07, 2017, 01:43:27 am »
The Mayor was a chief proponent of the project.  It's safe to say there is a vested interest in the appearance of success, or at least the lack of a stream of webcam footage being recorded that documents failure.
Offline FrankBuss
    • Frank Buss
« Reply #1017 on: March 07, 2017, 01:54:06 am »
And it is not even on a road. Imagine thousands of cars per day rolling over it. It wouldn't survive one day and may even cause car accidents and kill people, if the quality of the rest is the same as the electronics quality.
Offline Brumby
« Reply #1018 on: March 07, 2017, 02:11:35 am »
That seemed more than obvious to me.  The 'technology' is only a foil.  The game being played here is politics.
Offline ataradov
    • Personal site
« Reply #1019 on: March 07, 2017, 02:12:57 am »
The stream is up, but all the panels appear to be off.
EDIT: I guess this  explains it:
The Solar Roadways electrical system is currently undergoing maintenance. Please check back late next week.
"Your road is undergoing maintenance, check back in a few weeks, good luck with your insurance claims" :)
« Last Edit: March 07, 2017, 02:49:18 am by ataradov »
Alex
Offline Delta
« Reply #1020 on: March 08, 2017, 12:19:43 am »
Never mind their stupid random LEDs going dark, how many kWh has this pile of shite put into (or more likely consumed from) the grid?
Show us the data!
Offline Brumby
« Reply #1021 on: March 08, 2017, 02:15:38 am »
Show us the data!
I asked that question:
Yes .... I want to see the energy balance sheet.
They'll never show it.
« Reply #1022 on: March 08, 2017, 02:25:23 am »
Fire brigade called!  :-DD
You can't script this stuff!
The following users thanked this post: thm_w, Kean
Offline Brumby
« Reply #1023 on: March 08, 2017, 02:27:55 am »
Imagine the smoke that could be generated by a few thousand kilometres of these!
Offline ataradov
    • Personal site
« Reply #1024 on: March 08, 2017, 02:29:33 am »
I wonder when they will finally give up.
And it is not like something really stopped them from installing this at their house and figuring all that stuff there.
Alex
