Author Topic: EEVblog #632 - Solar Roadways Are BULLSHIT!  (Read 420056 times)
Offline Brumby
Re: EEVblog #632 - Solar Roadways Are BULLSHIT!
« Reply #1225 on: January 11, 2018, 01:57:14 pm »
* looks for the popcorn *
Online Fungus
« Reply #1226 on: January 11, 2018, 02:07:38 pm »
Like Yanks & Canucks! ;D
Canucks is easy, just count how many times they say "all-righty" per minute.  :popcorn:
Yeah, I'm gonna regret posting that.
« Last Edit: January 11, 2018, 02:15:09 pm by Fungus »
Offline Brumby
« Reply #1227 on: January 11, 2018, 02:18:02 pm »
My response was not so much on stereotypical phrases, but of commonly held beliefs about relationships - such as those between:
 - Americans and Canadians
 - Aussies and Kiwis
 - English and French
 - English and Scots
 - English and Irish
..etc.
Offline jonovid
    • JONOVID
« Reply #1228 on: January 19, 2018, 01:08:39 am »
more BS!
Solar Roadways accuse me of LYING!!!
this time its the LEDs.
Hobbyist with a basic knowledge of electronics
Offline ataradov
    • Personal site
« Reply #1229 on: December 22, 2018, 04:22:41 am »
It looks like solar roadway turned into a passive place to put sad trees.
Also, it is the end of December, where is the snow in Idaho?
Alex
Offline Brumby
« Reply #1230 on: December 22, 2018, 04:33:56 am »
You'd think they could at least have the LEDs flashing to make it look a bit more festive.
Offline FrankBuss
    • Frank Buss
« Reply #1231 on: December 22, 2018, 10:55:05 am »
Maybe they placed the flowerpots in the hope that people stop walking on it.
Online Fungus
« Reply #1232 on: December 22, 2018, 04:57:14 pm »
They could power them from the solar panels.
Offline darik
« Reply #1233 on: December 22, 2018, 08:17:16 pm »
And using solar roadways logic, they could then power the solar panels from the LEDs.
Offline PlainName
  • Country: va
« Reply #1234 on: December 23, 2018, 07:00:27 am »
They are powered from the solar panels.
Offline gildasd
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
« Reply #1235 on: December 23, 2018, 07:29:11 am »
That are powered by potted plant auric fields?
I'm electronically illiterate
Offline PlainName
  • Country: va
« Reply #1236 on: December 23, 2018, 07:35:48 am »
Whoosh  :palm:
Offline EEVblogTopic starter
« Reply #1237 on: January 18, 2019, 04:04:38 am »
Don't know if this has been posted, but a recent update from Sept on the website:
The SR3 testing at Jeff Jones Square in Sandpoint and at Marquette University in Milwaukee has been completed. We are grateful to the city of Sandpoint and all residents and visitors who served as our testers on this pilot project. This “real life test” gave us the information we needed to make important improvements to the design for SR4. We’ll share what we’ve learned, along with some insight into the array of civil engineering tests performed at Marquette.
The biggest challenge that we’ve found has been the manufacturing process. Each individual part worked fine, but putting everything together and subjecting them to the manufacturing process created some problems and a very challenging learning curve.
There are three fundamental features of the Solar Road Panels: the LED functionality, surface heating, and solar harvesting. Here’s what we’ve learned about each from the Sandpoint pilot project:
LED Functionality
SR3 has an array of LEDs, including red, green, blue, white, and yellow. Other colors and shades can be created by mixing the standard colors – we created a few extras for SR3 and will be working with more colors with SR4. These are individual high brightness LEDs designed for outdoor use. They worked great in all preliminary testing. We could turn them up so bright that they could actually hurt your eyes outside on a very sunny day. During SR3 testing, we worked to determine the optimal brightness levels for the LEDs in different situations. Now they automatically adjust themselves to the ambient light and we are pleased with how that is working.
The heavy vacuum of the lamination process is a very harsh environment for small electronics. The tiny LEDs were being damaged during this process. We experimented with many types of clear epoxies to protect them from the lamination process. We eventually found one that could handle the job and began producing panels.
When we initially installed the 30 panels at Jeff Jones Square, we programmed them to rotate through a series of patterns. It resembled a moving dance floor and the kids loved it. Later, we began to create some static images such as this earth design:
Earth Image at Jeff Jones Square
We left this up for 2-3 weeks, when we noticed something unusual: the blue LEDs began to fade (lower their intensity). Experimenting with other patterns, we noticed the same thing happening with the white and yellow LEDs. The red and green LEDs were not affected. This was confusing and frustrating, and we could not continue manufacturing panels until this was resolved.
After many conversations with the LED manufacturer, we learned that the blue, yellow, and white LEDs were made differently than the green and red LEDs. Together, after much testing, we came to the conclusion that the protective epoxy was having a chemical reaction with the LEDs and the sun was the catalyst.
This has been corrected for the SR4 design so that protective epoxies are no longer needed.
Heating
After two north Idaho winters, we’ve learned quite a lot with the heat testing results. Although SR3 was able to keep up with the snow in most situations, we’re increasing the heating capability of SR4 to allow for faster heating. This will allow the panels to more easily keep their temperatures up during heavy snowfall.
The Sandpoint installation used anodized aluminum panel retainers between the panels. Since there is no heating in the gaps between the panels, these metal pieces took on the ambient temperature. We learned that they could create an ice bridge during really heavy snowfall combined with extremely low temperatures. We’ve designed a rubber replacement – a “t-channel” for the aluminum units. This new design also greatly simplifies installation and maintenance.
Solar Harvesting
The most disappointing aspect of the pilot project in Sandpoint has been the energy harvesting. In order to increase the number of solar cells in the SR3 panel (SR2 was 36-watts and SR3 is 44-watts), we used a parallel/series combination of cell connections. We also created a Consolidator Board to consolidate the power collected by the panels. We used a parallel/series combination on this board to create the power input requirements for the micro-inverters.
Although all technical solar information I have found says that you can parallel solar power, we found that to be a very bad idea. All of the SR2 panels had their solar cells connected in series, so we’d never seen this problem. What we found was this: every panel produced power, but we couldn’t get them to combine properly to meet the input requirements of the micro-inverters. We were never able to “see” more than 1/3 of the power being produced. In addition, we learned that the extra laminate that was used in SR3 as compared to SR2 due to design changes interfered with solar gain. These problems have been eliminated with the new SR4 design.
For SR4, we found a way to maximize the solar cell area while maintaining a series-connected system. We also increased the wattage from 44W (SR3) to 50W (SR4). In addition, we’ve going from 17.6-percent efficient solar cells (SR3) to 22.5-percent efficient solar cells (SR4). We’ll always be able to increase the solar gain over time as the solar industry continues to advance and make more efficient products for us to incorporate. All of this means that we’ll be able to produce a lot more power with the SR4 panels.
We’ve also replaced the energy monitoring system with a more “Solar Road Panel friendly” monitoring system: one with a much larger input range that doesn’t require the parallel/series configurations.
When we get the SR4s installed, we’ll activate the system on the city’s website. For now, the current energy monitoring system reads zero because the panels have been disconnected from it.
Additional SR4 Improvements
Another hard lesson learned: the cables that were used with the SR3 panels had a plastic jacket. Over time, this plastic jacket became brittle and cracked, allowing water into the cable. After several months, some of the panels began to fail. We’d see only half of the panel lit up. Eventually, the LED patterns would become corrupted and the panel could no longer be communicated with.
We began removing the damaged panels and inspecting them. We found damaged cables where water had entered and began corroding the wires inside. This corrosion creates resistance, which in turn robs the panels of power. This means that the microprocessor, the LEDs, and the heating elements are not receiving the power that they need to function properly.
The new SR4 design uses and molded rubber cable which remains much more flexible after the lamination process.
Civil Engineering Tests Completed
As part of our third contract with the US Department of Transportation, our panels have been undergoing testing at the civil engineering department at Marquette University in Milwaukee, Wisconsin. They performed the following tests:
Shear testing
Freeze/Thaw cycling
Moisture conditioning
Accelerated load testing (simulates 15-years of truck abuse in 3-months)
They were so impressed by the results of the testing that they want to co-author a journal paper with us about the overall test program. We’ll be releasing the findings in a scientific engineering journal.
Summary
The Sandpoint pilot project gave us very valuable information: It allowed us time to tweak the LED intensity tables (the LEDs get brighter when the sun does likewise), adjust the heating profile with real time weather patterns, and taught us how to change our manufacturing process to solve the problems that were presented. It also pointed out the weaknesses in the SR3 panels, allowing us to finalize the SR4 design.
We decided from the very beginning of our Solar Roadways journey to be as transparent as possible. We realize that is not the way startups usually operate, but we wanted to be different. We are doing this work for the world and we wanted to allow our fan base to come along with us on the journey. Most people have realized that problems are part and parcel of the learning curve with inventing. We’ve been grateful to have so much support as we’ve worked to improve the panels and get them ready for mass production.
Since we’re done with the pilot project, and since the damaged cables are creating problems for the SR3 panels, we will shut down the Jeff Jones Square installation until spring, when we will replace the system with the new SR4 panels.
The first of the SR4 circuit boards have been received and tested. The first SR4 panels should be completed by the end of January. They will be tested extensively. We’ll put a few in our parking lot on Pine Street in Sandpoint, where everyone will be welcome to visit. Others will go to temporary exhibits. We just announced that one of those events will be the Treefort Music Festival in Boise in March. When the weather warms up in the spring we’ll replace the SR3 panels with SR4 panels at Jeff Jones Town Square in Sandpoint.
The SR4 will become the first commercially available Solar Road Panel
The following users thanked this post: djos
Offline FrankBuss
    • Frank Buss
« Reply #1238 on: January 18, 2019, 07:01:15 am »
I'm sure they can make a career as politicians when this projects finally fails. There were "challenges", and the project "has been completed", instead of writing there were so many problems and it still doesn't work. And I wonder why they didn't write any details at all about the accelerated load test etc. of the university. Let's see what they mean with "impressed"  :popcorn: But SR4 sounds like a major redesign, so I guess this needs to be tested again?
Offline Towger
  • Country: ie
« Reply #1239 on: January 18, 2019, 08:14:00 am »
It is an interesting report.  The difference manufacturing process for blue/white leds is something the most of people with a interest in electronics know about.  'Plastic' cables for outside use rather than the likes of HO7 was silly.  I like how in the SR4 they increased the output from 44 to 50 watts and 'in addition' the solar cell manufacturer increased the efficency.
« Last Edit: January 18, 2019, 08:17:35 am by Towger »
Offline Brumby
« Reply #1240 on: January 18, 2019, 01:27:14 pm »
I can see a big secondary market in kids disco dance floors...
Offline coppice
« Reply #1241 on: January 18, 2019, 02:48:40 pm »
I expect the next revision will be pressure sensitive, and allow you to play dance dance revolution.
Offline max_torque
    • bitdynamics
« Reply #1242 on: January 18, 2019, 03:16:04 pm »
Hurray, their totally rubbish and hugely in-efficient solar panels are still hugely in-efficient but slightly less rubbish.  The "problems" they found were obvious to any decent engineering team (stuff stuck in the ground gets wet, wow, who'd have known that eh...) and should have be part of any robust engineering FMEM program.
They also say "as more efficient solar panels become available our output will increase" but of course, people making conventional solar arrays (where they actually point the panel at the sun....) will also benefit, so in a like for like comparison it's irrelevant. The fundamental efficiency of a solar road is always limited by its necessary installation parameters rather than the panels it utilises (as has been said all along)
They also admit they struggle to joint / join their individual panels. If this is an issue with only people walking on them, what happens when a 40 ton truck driver over them at 40 mph?
And finally "we have increased the heating power for SR4" oh great, even less total energy export as you are therefore using more of the energy to heat each panel.  So what you have developed is not actually a "solar roadway" but just a "heated roadway", which incidentally, already exist and are used all over the world to prevent snow and ice build up in critical locations....
Online Fungus
« Reply #1243 on: January 18, 2019, 04:50:51 pm »
Riiight, so if you multiply the number by 10 (or whatever), how does the math work out?
Not true. There's a physical limit that solar panels are already approaching.
[/quote]
How much do you estimate, based on the current ones? Finger in the air.
Offline coppice
« Reply #1244 on: January 18, 2019, 05:13:50 pm »
It is true, but not in a useful way. See Zeno's paradoxes. There will always be a new generation of the product coming up which gets just that little bit closer to the theoretical limit, when you are already almost there. This allows people in most disciplines to correctly but deceptively keep saying there will be further improvements, when all the useful improvements which are possible have already been made.
« Last Edit: January 18, 2019, 07:57:30 pm by coppice »
Offline boffin
« Reply #1245 on: January 18, 2019, 06:58:57 pm »
For SR4, we found a way to maximize the solar cell area while maintaining a series-connected system. We also increased the wattage from 44W (SR3) to 50W (SR4). In addition, we’ve going from 17.6-percent efficient solar cells (SR3) to 22.5-percent efficient solar cells (SR4)....
Absolutely stunning.  With a 27.8% increase in panel efficiency, they've managed to add only 13.6% output to their panel.
Online nctnico
« Reply #1246 on: January 18, 2019, 09:20:52 pm »
(A)DSL anyone? During my EE studies I learned that 9600 baud was the maximum transmission speed physically possible over a phone line.
Offline boffin
« Reply #1247 on: January 18, 2019, 09:42:40 pm »
9600 isn't the limitation of the wire the endpoint to the central office (CO), which is where ADSL runs; so that kind of comparison is just silly.
Offline coppice
« Reply #1248 on: January 18, 2019, 09:49:38 pm »
You should ask for your money back. Phone lines have never had a limitation of 9600 baud. On the other hand ADSL only runs at 4000 baud.
The following users thanked this post: boffin
Offline PlainName
  • Country: va
« Reply #1249 on: January 19, 2019, 07:26:14 am »
Wood/tree error.
Rather than be pedantic about the detail, think about what he's trying to get across: the state of the art changes and things that one wouldn't previously dream of become the norm. Further, although the first commercial ADSL modem probably ran pretty well, I bet there were a number of prototypes that led up to the released product that looked great on paper but didn't survive reality.
Hmmm. I guess now someone will say that of course they worked first time because there was a standard to conform to, or something like that. All I can say to that kind of thing is 'whoosh'.
