Author Topic: EEVblog #614 - Cebit 2014 Highlights Download  (Read 22303 times)
Online EEVblogTopic starter
« on: May 09, 2014, 12:37:08 am »
Dave attended the Cebit 2014 event in Sydney at Homebush Olympic Park. Here are some highlights.
The EX¹ the worlds first PCB printer. It prints silver conductive ink onto FR4, paper, mylar, or many other types of substrate.
https://www.kickstarter.com/projects/cartesianco/the-ex1-rapid-3d-printing-of-circuit-boards
GoFar, a wireless car monitoring startup.
The University of Newcastle Robotics group NuBots:
http://www.newcastle.edu.au/research-and-innovation/centre/engineering-built-environment/newcastle-robotics-laboratory
Showcasing the robots use in the RoboCup challenge.
Offline Unixon
Re: EEVblog #614 - Cebit 2014 Highlights Download
« Reply #1 on: May 09, 2014, 05:51:51 am »
I wonder how strong do these silver traces stick to the base material. Will this printed circuit be repairable?
And, eventually, what do they say about printing over a solder mask as well?
« Reply #2 on: May 09, 2014, 06:35:01 am »
It's only ever going to ever be for quick prototypes, so solder mask isn't really needed.
Offline jeremy
« Reply #3 on: May 09, 2014, 08:05:40 am »
I have actually played with the prototype boards from a while back, the stickyness seemed to be extremely dependent on the substrate. At the time, the paper was definitely strong enough to withstand anything that FR4 could. And you can stick the paper on a sheet of plastic for more rigidity. My interest is in experimenting with the device to create controlled impedance traces and funky shaped PCB antennae. One could potentially even make the system closed loop; measure the resistance as you print and then optimise.
But then again, Ariel is a friend of mine and I am backer #1, so I'm a little biased  ;)
Offline fcb
    • Electron Plus
« Reply #4 on: May 09, 2014, 09:19:59 am »
That GoFar is neat, although my inner pedant was activated at 16:04 by "breaking"..
Offline envisionelec
« Reply #5 on: May 09, 2014, 12:16:16 pm »
My pedant is annoyed by your spelling of braking.  :-DD
Offline Carrington
« Reply #6 on: May 09, 2014, 02:19:49 pm »
Only one questions:
What Dave was watching, a few seconds before?
 :-DD
Note: I deleted the second part, I found it funny at first, but it is not.
« Last Edit: May 09, 2014, 03:19:39 pm by Carrington »
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
« Reply #7 on: May 09, 2014, 02:55:17 pm »
First: What Dave was watching, a few seconds before?
You asked.
Offline Carrington
« Reply #8 on: May 09, 2014, 03:00:35 pm »
You asked.
:-DD
I just hope that this does not create any misunderstandings.
If that bothers to someone I delete it immediately.
Thanks Dave.  ;)
Space Weather.
Offline baljemmett
« Reply #9 on: May 09, 2014, 03:32:23 pm »
Here, have a free [sic] ::)
« Reply #10 on: May 09, 2014, 04:26:41 pm »
I do not like that barstool design, as most are way too cheaply made, and tend to break at the base where the spun steel joins the leg.
« Reply #11 on: May 09, 2014, 06:49:46 pm »
Dave, do you still have that big HP inkjet plotter? I foresee an ink change on that one coming soon to change 2 of the print heads to silver nitrate in water and Citric acid in water, both adjusted to equal molarity so you can print your own PCB's.
Offline fcb
    • Electron Plus
« Reply #12 on: May 09, 2014, 10:21:06 pm »
Pay attention in the back.
So you didn't see the video (16:04) then.. that's how the GoFar app spells it...
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #13 on: May 09, 2014, 11:18:12 pm »
Maybe it's intentional. You are breaking your budget by braking too often. ;D
The PCB printer looks really promising. I must say, I really like the guy's enthusiasm, you can just see he loves his work.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline dentaku
« Reply #14 on: May 10, 2014, 12:52:52 am »
Being able to print out a circuit is great for prototyping. I hope it just keeps getting better and more affordable but I have to say it sure looks ugly close up :)
I also don't know why you'd bother using paper even for a prototype.
Offline Steffen
« Reply #15 on: May 10, 2014, 09:48:18 am »
At first I thought: "Has Dave been to Hanover (Germany) in March this year and made a late upload of his visit?" But then he was in front of an unknown building and told about Sidney and so on. Up to this point I thought, that the CeBIT is only present in Hanover, because it's one of the worlds biggest IT fairs so far. It's interesting to know, that such events are also present on other continents.
Offline Unixon
« Reply #16 on: May 10, 2014, 03:16:40 pm »
When they first said they made a PCB printer I though about a different kind of device - "Desktop Board House" - a small device with size from that of a desktop laser printer up to a big office copier that can manufacture small or medium size (paper size for reference) high quality boards in small quantities using the same mechanical and photochemical processes that a regular board house uses to manufacture PCBs in huge quantities.
Imagine this: you click "Print" button in your EDA, it sends GERBER files to the printer, after few hours your PCB is ready! Real FR4, 2+ layers, not a paper or whatever.
Offline retrolefty
« Reply #17 on: May 10, 2014, 05:07:55 pm »
Was it really all controlled by an Arduino board? That part seemed to be too quick and not a real clear shot.
Offline Mr Simpleton
  • Not the sharpest knife in the drawer
« Reply #18 on: May 10, 2014, 05:20:29 pm »
Having used the LPKF for years, the main problem is to get proper double layer boards and then get connectors soldered on both sides. The way LPKF implements through hole plating is cumbersome...  Still neat for prototyping, but what happens when Cartesian go bust, will the ink cartridge be possible to refill?
Offline chicken
  • Rusty Coder
« Reply #19 on: May 10, 2014, 05:31:40 pm »
This was a very interesting video, I really liked the interviews!
Dave should invite startups to his lab. Tearing into a gadget while the original designer comments on the design desicions, compromises, prototypes, manufacturing headaches etc. How cool would that be?
Offline derbenni
« Reply #20 on: May 10, 2014, 06:58:23 pm »
Funny, that's exactly what I thought as well :)
Offline Ariel
« Reply #21 on: May 11, 2014, 01:39:34 am »
Actually Jeremy, we've made a lot of improvements to adhesion of the silver to the boards since you last saw the process. We now sandblast and chemical treat the FR4 and kapton with a coupling agent that makes a chemical bond between the two, instead of relying on a weak mechanical bond like before.
At CeBIT we had a FR4 board that we were handing out to hundreds of people all day and telling them to try to scratch at a particular trace with their fingernail. At the end of the 3 days the trace was continuous and just as conductive as before.
As for solder mask, we're working on a new ink chemistry to do this, so it'll just be a matter of throwing another cartridge in the printer, but at the moment it's not really necessary.
Offline Ariel
« Reply #22 on: May 11, 2014, 01:45:35 am »
Printing on paper isn't really meant for serious prototypes, just like printing on fabric isn't meant for complicated circuits. They're both just additional possibilities that more 'creative' types than us can use to make cool new things  :P
When you said it looks ugly, I thought you were talking about the printer! But yeah, the circuits aren't necessarily lookers from close up, I'm just happy they work  :D
Offline Ariel
« Reply #23 on: May 11, 2014, 01:54:54 am »
That's exactly what we're working towards! Well, not the idea of using the same chemical process as board houses, but it being as easy as pressing print and getting your board-house-level circuit. Not sure if you missed it, but the printer can print on FR4, paper is just a bonus.
Yep, really a shield on an arduino mega. I'll get some nice photos of it later.
Haha, well we're hoping not to go bust. Either way, we'll be making a complete tutorial on how to refill your own cartridges, so there won't be any danger anyway. The actual point of the video is to let people refill them with different things to experiment with resistive and insulative inks, and other wonderful things.
Agreed!
Offline VK3DRB
« Reply #24 on: May 11, 2014, 12:11:58 pm »
I have never before heard a SOIC pronounced "SOWIC". It is normally pronounced "SOYCK". Either he is too young to know or things have changed. Datasheets don't give pronunciation. Linux is pronounced "LEE-NUCKS" but I heave heard newbies pronounce it "LY_NUCKS" after Linus Torvalds. This does not bother me at all. It is but an observation.
But one thing that really gets up my nose is young Sesame Street Australians pronouncing Z as "ZEE" rather than "ZED". The schools have not even been able to teach our kids the alphabet.
« Last Edit: May 11, 2014, 12:25:11 pm by VK3DRB »
