Thanks for the great mic series.
I remember the story about the heat resistors – acting like dehumidifiers.
Humidity is one of the condenser mics worst enemy, where leakage in the capsule / diaphragm, pcb and wiring can lead to excessive noise and loss of sensitivity. In the 60s, some manufactures overcame this problem by using RF modulation.
Instead of the traditional high impedance capsule load, the RF microphones are still utilizing a condenser capsule, but now the capacity variations are used to modulate a high frequency signal (10 MHz typ.).
Several modulations types (AM, FM, PM), where used. The RF mic technique is still in use today in Sennheiser’s Academy Awarded MKH series.
Best Regards
Peter
