thanks, pickle
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
looks affordable and ships from the US if going to the US. works for me.
they have too many choices, though.
I did like the color that dave used. is that technically grey? its not really green, is it? and its obviously not dark blue, as the stuff he had before was dark blue. the lighter color does help brighten up the place, so I'd go with lighter vs darker, if given a choice.
I assume I want double layer and not triple, yes?
what's all the stuff about grounding points, though? they seem to have a few styles and I'm not sure what to get.
btw, is it really sufficient to ground it at just one point? would it be useful to ground it every 1 metre's length, or so? can you add extra snaps to it? if I cut it into sections, I'd want to add grounding to each section, of course.
